Author Topic: swingarm swap questions.  (Read 1051 times)
Offline verboten1
  • Der König
« on: August 27, 2009, 05:47:50 AM »
I have an '86 ninja swingarm I am going to run on my 550, it is only slightly narrower than the stock part, so I will ned to make spacers (approx 5 mm each).
my question is, do I center the swingarm in the frame, and then use spacers on the axle to line the chain up, or do I center the wheel in the swingarm, and center it to the chain that way?
THANKS !!!
1975 CB550F
1982 XV920
2000 KLR65085
Offline Alan F.
Re: swingarm swap questions.
« Reply #1 on: August 27, 2009, 06:34:45 AM »
That looks pretty good, and not too much longer than stock too.
If that swingarm has the same amount of material on both sides of the pivot area, just make spacers and center it up.
Mount the wheel in the swingarm and center it up, then meaure for spacers to keep it centered.
Then figure out how to make your chainline correct, some guys will remove the studs and chuck the sprocket carrier in a lathe and turn it down to make things fit.
Others must make shims to fit behind their rear sprockets to make things fit.
Cycle-X has good quality offset front and rear sprockets that may help, but they're not as cheap as the regular units if it matters.
-Alan
Offline Triffecpa
« Reply #2 on: August 27, 2009, 10:09:59 AM »
If you are going to retain your stock rear wheel, then just center the swingarm in the frame and center the wheel in the swingarm and you should be good to go.
Tracy
Offline verboten1
  • Der König
« Reply #3 on: August 27, 2009, 06:46:46 PM »
thanks all!!!
i like the way it looks, not sure if I will polish it, or PC it black
1975 CB550F
1982 XV920
2000 KLR65085
