Author Topic: Recommend good manometers.  (Read 2695 times)
Offline Tretnine
  • Prove it,
  • Figuring it out, one expletive at a time.
    • http://www.behindbarsmotorcycle.com/
« on: September 23, 2009, 06:05:42 AM »
I've finally decided that this would be a good investment. I need a manometer. I do not want to build a 5' tall water pipe/lean to, I want the tool. I would like one that would last and something I will not feel I need to replace because what I have is cheap. Recommendations and comments about what you have or have tried are welcome.
2009 Kawasaki Concours, 1978 cb550k, 2006 BMW F650GS
Member of the AMA
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: Recommend good manometers.
« Reply #1 on: September 23, 2009, 07:22:27 AM »
I have the Morgan non-mercury and I sucked the fluid out once- it is OK to use.
People seem to like the Morgan carbtune that buy it, I might get one down the line.
Offline CaféElite
  • 1975 CB550
« Reply #2 on: September 23, 2009, 08:28:32 AM »
If all goes well I will hopefully use mine for the first time this weekend.
CB550's
Offline Tretnine
  • Prove it,
« Reply #3 on: September 23, 2009, 11:15:53 AM »
any others? So far this one seems 'ok'
Member of the AMA
Offline JBMorse
    • Travel Blog
« Reply #4 on: September 24, 2009, 07:26:18 AM »
I broke down and bought a morgan carbtune this summer and it was great.  It's a real nice tool, simple, good quality and I like the fact that it has no fluid, just metal rods that move.  It isn't the cheapest way to go, I paid around $100, but it is real nice to use and I think it will last forever.  It comes from England but shipping didn't take long, I had it in a week.  It came with very good instructions too.
I also didn't want a great big contraption that I made myself, mainly for storage reasons.  There's plenty of room in my toolbox for the carbtune.  The only downside is that it's more expensive than a homemade thing, but I don't think you'd regret buying it.
Check it out:
http://www.carbtune.com/
1971 CB500K
Offline Tretnine
  • Prove it,
« Reply #5 on: September 24, 2009, 11:28:45 AM »
I'm liking this carbtune idea. Any special tools needed or special attachments I should get so it will work, or is that it?
Member of the AMA
Offline JBMorse
    • Travel Blog
« Reply #6 on: September 24, 2009, 04:52:30 PM »
This would be true no matter what gauge you buy, but I recommend the carb adjuster tool.
http://www.motionpro.com/motorcycle/partno/08-0022/
I think morgan also sells one on their website.  It's not easy to make the actual adjustment using a screwdriver and wrench.  If you've got a welder, you could weld a handle to a socket (8mm I think) and run a small screwdriver through it instead.
There are also auxiliary gas tanks.  I just used my own gas tank by coupling some more hose to it when it was off the bike, resting on the bench.
Good luck!
Jeremy
1971 CB500K
Offline gregimotis
  • poet laureate; SOHC4.
« Reply #7 on: September 24, 2009, 06:12:51 PM »
+1 on the Morgan carbtune.
So easy, even I figured it out the first try.
Offline tomsweb1
  • '78 CB750A
  • '78 CB750A
« Reply #8 on: September 24, 2009, 06:18:28 PM »
I purchased 4 vac gauges from my local auto supply store... they were inexpensive and worked very well.
 They were 15 bucks each, and I bought the adapters from a Honda dealer, they were also 15 bucks for the set.
 75 bucks I had my carbs balanced beautifully.
Present: 1978 CB750A, 1978 CB400A, 1983 Nighthawk 550, 1984 CM250C
Past: 1977 XL100, 1982 KZ1300
Offline ev0lve
« Reply #9 on: September 24, 2009, 07:35:41 PM »
+2
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #10 on: September 24, 2009, 07:38:43 PM »
i had vacuum gauges but i could never get them to stop bouncing enough for me to read the things. the adapters that connect the hoses to the carbs did have restrictors but they really didnt seem to help. i'll be buying a morgan carbtune too as soon as i can.
Mark Twain - Notebook, 1894
Offline gregimotis
« Reply #11 on: September 24, 2009, 08:07:51 PM »
I'm voting Iggy for the best sig on the board.
Offline ev0lve
« Reply #12 on: September 24, 2009, 08:32:50 PM »
These aren't the droids you're looking for. Move along. ;D
Offline medic09
« Reply #13 on: September 24, 2009, 08:38:02 PM »
Another vote for Morgan Carbtune.  Easy to use, durable.  Mine's loaned out since I don't need it often, and it has stood up to the use well.
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
Offline Tretnine
  • Prove it,
« Reply #14 on: September 25, 2009, 06:14:10 AM »
HAHHAHHAHAHHHAH!
These aren't the droids we're looking for.
Member of the AMA
