Author Topic: tappet adjustment??  (Read 877 times)
Offline apostrophe28
tappet adjustment??
« on: September 23, 2009, 10:41:30 AM »
ive got the theory of how to adjust the clearences, ive got the tappet covers off....and now i'm not sure where i should be measuring for the .08mm clearances?!
is it between the very bottom disk part and the arm because mine looks to have about 1/4 inch room rite now..please help
77' 750k
1977 750k
Offline Gordon
  • 750K1, 550K2
Re: tappet adjustment??
« Reply #1 on: September 23, 2009, 10:54:56 AM »
The bottom of the screw that you turn to set the clearance is what comes in contact with the top of the valve stem, and that's where you measure.  You can't actually see the spot with the valve cover on, but you can get your feeler gauges in there.
Offline jeepster
« Reply #2 on: September 23, 2009, 11:13:45 AM »
What bike? On my Nighthawk you measure between the rocker pad and cam lobe.
"An ounce of prevention is worth more if you break it up into nickel bags."
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: September 23, 2009, 11:27:11 AM »
Offline jeepster
« Reply #4 on: September 23, 2009, 11:28:59 AM »
Offline BVCB650
  • Too Much Thin Air
« Reply #5 on: September 23, 2009, 11:32:42 AM »
Yea, we have it easy.
1979 CB650, 25K miles, recently refurbished
