Author Topic: Bike Suspension Bible  (Read 14191 times)
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« on: October 11, 2009, 08:11:06 PM »
I found this very informative link while searching google.
http://www.carbibles.com/suspension_bible_bikes.html
Offline HedNut
  • Underwater Basket Weaving
Re: Bike Suspension Bible
« Reply #1 on: November 25, 2009, 09:56:38 AM »
VERY COOL!  Nice find~!
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: November 25, 2009, 01:07:25 PM »
Good stuff, thanks!
mystic_1
- John Augustus Shedd
  • Like a well oiled
    • Undead Asphalt
« Reply #3 on: November 25, 2009, 01:16:38 PM »
I had a question that page didn't answer, I'm doing a gsxr1000 fork swap and the steering axis is tighter to the neck bolt than stock by about a half inch.
what will that do?
will it give me the shakes without a damper?
edit: it's 2 inches or so wider.
« Last Edit: November 25, 2009, 01:26:41 PM by Industrial Cafe »
Offline mystic_1
  • 1970 CB750K
« Reply #4 on: November 25, 2009, 02:14:11 PM »
I'm not following, are you swapping the trees and the new ones have less offset?  If so that'll reduce your trail, but by how much is hard to guesstimate.  You'll have to measure it.
mystic_1
  • Like a well oiled
    • Undead Asphalt
« Reply #5 on: November 25, 2009, 04:13:10 PM »
 I'm swapping the whole thing.
 I have a pic of the difference.
edit: what does reducing the trail do to your handling if the rake remains the same?
« Last Edit: November 25, 2009, 08:31:30 PM by Industrial Cafe »
Offline tbpmusic
« Reply #6 on: November 26, 2009, 06:13:22 AM »
That would make the steering a bit "quicker".
Here's a little spreadsheet that will let you determine the geometry fast and easy - you just need a tape measure and a stick. Based on the immutable laws of right triangles.....
http://home.comcast.net/~tbpmusic6/RakeTrailCalc.xls
"If you can't fix it with a hammer, then it's an electrical problem"
Bill Lane
 '71 CB450 Mutant/ '75 CB200/ '81 CM200/ '71 C70M
Offline mystic_1
  • 1970 CB750K
« Reply #7 on: November 26, 2009, 06:29:37 AM »
Yup, bike will steer quicker but will be somewhat less stable in straight lines/high speeds.  Four to six inches of trail is the target zone that a lot of builders go for.  Too much trail isn't so bad (heavier steering) but too little trail can lead to tank-slappers.
mystic_1
  • Like a well oiled
    • Undead Asphalt
« Reply #8 on: November 26, 2009, 06:39:52 AM »
i figured that.
    then it would probably be a good idea to put a steering damper on it...
Offline mystic_1
  • 1970 CB750K
« Reply #9 on: November 26, 2009, 06:49:33 AM »
Re-checked by statement earlier btw and reducing offset actually increases trail.  So, you'll be fine.
1/2 inch reduction in offset won't affect the trail a whole lot anyway.  Stock trail is like 3.8" IIRC.  Looks like 1/2 inch offset reduction should put your trail in the neighborhood of 4.2"
BTW I should have said earlier "Four to six inches of trail is the target zone that a lot of chopper builders go for".
mystic_1
« Last Edit: November 26, 2009, 06:55:07 AM by mystic_1 »
  • Like a well oiled
    • Undead Asphalt
« Reply #10 on: November 26, 2009, 06:59:45 AM »
 I noticed the later cb750's had a half inch or so less trail to their trees than my 71.
Offline Square
    • Square Pinstriping & Lettering
« Reply #11 on: November 09, 2011, 09:44:29 AM »
Thanks for the link,
i know its an old post but winter is coming and its time to get so work done..
Offline rklystron
  • I have not failed. I've just found 10,000 ways that won't work. Thomas A. Edison
« Reply #12 on: November 10, 2011, 03:34:39 AM »
Great find. I will be building or greatly modifying a stock frame and this information is invaluable. Thanks again IC.
1970 CB750 K0 (Bought in 73)
1972 XL250 (Bought new in 72)
1973 ST90 (Free)
1975 XL250 (Free)
1975 Rickman CR750
1982 CBX1000 Pro-link
1975 CB750 DRAG BIKE
1977 Custom Built CB750 Sturgis Bike (GL front end).
1977 CB750 F2 (Big Resto)
1977 CB750A (Auction Buy)
1978 CB750 K8 (My San Francisco ride)
1984 VFR750 (Bought New)
Offline caferacer750
  • yup it getting there
  • ride it
« Reply #13 on: June 29, 2012, 06:51:16 AM »
very nice write up
thanks for posting it
Offline Trevdawg
« Reply #14 on: June 29, 2012, 06:53:18 AM »
Nice
Offline jnyrav
« Reply #15 on: April 30, 2017, 09:11:47 AM »
This is great, thanks for posting
