Author Topic: What did you do to your bike today ?  (Read 3835749 times)
0 Members and 16 Guests are viewing this topic.
« Reply #33575 on: January 04, 2026, 02:59:20 PM »
You get the Lotus Root pipes nice and hot for sure!
« Reply #33576 on: January 04, 2026, 05:01:15 PM »
Steve….. The K1 is running on a perfect NOS set of HM300’s I picked up about 10 years ago. When new, I took an 1/8” drill bit and drilled out the original drain holes. Originally the hole is only in the thin outer muffler shell. The stub end of the head pipe is in there too, so I went through it as well. I clean them out a few times a year and blow in some WD40.
On start up today they drool out water for about 5-6 minutes. I ran the bikes for three times that long. After it cooled a bit I blew in some WD. They still look like new. The K3 has a lovely, stainless steel Hindle 4-1 pipe. It blows any moisture right out the back!
« Last Edit: January 04, 2026, 07:55:53 PM by BenelliSEI »
« Reply #33577 on: January 04, 2026, 06:42:55 PM »
 I replaced the broken Tarozzi shift lever that broke when I dumped the 750K1 Rat Race over in the shop, it actually snapped when I picked it up. Fortunately, that was the only damage, and I could buy a new pedal. I finally understand how the Tarozzi adjustment holes line up with the locating pin and how messed up the PO had it when I got it, I used a machinist file to remove the burrs he left behind.
Offline papi_sosaa
  • Millennial
« Reply #33578 on: January 10, 2026, 08:26:51 PM »
Entered my bike into the Toronto International Motorcycle Supershow.
1982 Honda CB650SC Nighthawk Cafe Racer
« Reply #33579 on: January 11, 2026, 06:28:12 AM »
How did it go? I used to take bikes down but got stuck in a big snow storm a few years ago (on the highway with a trailer full of bikes). Never again.
« Reply #33580 on: January 11, 2026, 07:26:10 AM »
That is an interesting bike!! Looks like the crank is in line with the frame and a 90 degree change to the drive sprocket?
« Reply #33581 on: January 11, 2026, 09:04:15 AM »
Steve….. my very old Cleveland (SOLD). Two stroke, multi-plate clutch, with a two speed gearbox. The engine dropped out of the frame in minutes and could be dismantled almost as quickly. All made in Cleveland, even their own chains. VERY clever design, check it out here:
https://www.olsens.no/motorcykle/cleveland1.htm
The bike at the back of the photo was built by another CVMG member. It’s really an old bicycle fitted with a two-stroke washing machine engine and a lot of other old scrap. It called it a “Maytag” and had many of us convinced it was a real brand!
« Last Edit: January 11, 2026, 09:13:10 AM by BenelliSEI »
Offline pickleknuckles
« Reply #33582 on: January 11, 2026, 10:09:13 AM »
That's pretty cool.
That Maytag is great too. Got any other pics of it?
Sent from my Pixel 8 Pro using Tapatalk
« Reply #33583 on: January 11, 2026, 12:50:57 PM »
That's pretty cool.
No but I found a UTube video. Search “the Maytag Flyer”. Insanely clever!
« Last Edit: January 11, 2026, 12:55:19 PM by BenelliSEI »
Offline papi_sosaa
  • Millennial
« Reply #33584 on: January 11, 2026, 07:10:57 PM »
I came last in my class but because there were under 10 bikes, I still got a plaque and some money haha. First time I've ever done something like this so I'll still take it as a win.
Asked the judge for some advice after the show and he said my bike was clearly budget compared to the others but probably looked the most like a cafe racer.
The cafe class is small so if I wanted a chance of winning something, I had to go up against the professional builders. My bike was the only "independent" bike in the class and I suppose it's hard to compete against a pro shop that has the resources and can spend $100k+ on their show bikes.
« Last Edit: January 11, 2026, 07:13:23 PM by papi_sosaa »
« Reply #33585 on: January 12, 2026, 02:28:07 PM »
That's pretty cool.
Wow!! That was a huge transformation!
« Reply #33586 on: January 12, 2026, 02:30:15 PM »
That's pretty cool.
Congrats on the show. The guy that built the “Maytag” is a brilliant fabricator!
