Author Topic: Cb750K0 Tool tray and tools compatibility  (Read 1363 times)
Offline AshimotoK0
  • CB400/4, 69 CB750K0, '69 CB250SS, CB350K1 CB500K0
« on: November 27, 2009, 04:57:29 AM »
My OCt '69 750K0 is missing the tool tray for some reason. Am I correct in thinking this part was the same up to the K6? i.e P/N 50341300010 ?  I think it changed to 50341392000 on the k6.
Does anyone have a photo of the correct tools for the K0 and which models had the exact same tools.
cheers -  Ash
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.”
Offline GammaFlat
Re: Cb750K0 Tool tray and tools compatibility
« Reply #1 on: November 27, 2009, 05:32:48 AM »
My K6 has a plastic tray.  I had a K0 that had a steel tray (5/70 build date).
Oddly, the K6 has a steel chain guard and the K0 a plastic one.
« Last Edit: November 27, 2009, 05:44:23 AM by GammaFlat »
K6
85 Goldwing
Offline Simpson
  • I ain't no
  • Aged to perfection
« Reply #2 on: November 27, 2009, 05:44:07 AM »
tray on my 1970 spring k0
1970 CB750 K0
1975 CL/CB 360 Mix
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #3 on: November 27, 2009, 06:31:27 AM »
as far as i know theyre all compatible from 1969-1976. i have a k0 one in my k4 frame.
Mark Twain - Notebook, 1894
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
« Reply #4 on: November 27, 2009, 07:37:41 AM »
The one in the pic looks like the one on my K5 which is also metal.
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
Offline AshimotoK0
« Reply #5 on: November 27, 2009, 07:58:32 AM »
According to the parts manual the part number changed after the K5 so I guess the ones after k5 may be plastic. I can now search Ebay for a metal one.
Anyone got a picture of a genuine toolkit for the K0?
« Reply #6 on: November 27, 2009, 08:21:44 AM »
Toolkit and contents are shown in partsbook, I believe.
 On the K4 I am riding the tray is cracked in 2 places, never seen that before.. musta run with the tools in it for a long time..
Offline AshimotoK0
« Reply #7 on: November 27, 2009, 08:49:31 AM »
Did the K0 toolkit have this part in it? 89202283000  It looks like a wrench with a double hex cutout at one end, plain at the other?
Offline Raul CB750K1
« Reply #8 on: November 27, 2009, 10:40:00 AM »
I'll tell you what I did. Looked at the parts manual and wrote down which spanner sizes were included in the original toolkit.
Went to the hardware shop and bought spanners of the same size, medium quality. Cheap enough for me, and much better than the originals in case of a breakdown. I also bought a screwdriver with a set of bits, and pliers. Actually I ended up doing the same with old my bikes, having put the original toolkit on storage.
For the wheel axle nut I bought a box-end spanner and cut it so it would fit in the toolbox. I don't need the open-end, and I have more leverage than with the original spanner+leverage bar. I also carry some fuses, and a set of cables and cable-ends in case I need to replace a clutch or throttle cable.
Offline Simpson
  • I ain't no
« Reply #9 on: November 27, 2009, 11:05:30 AM »
should be about right
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Seamus
« Reply #10 on: November 27, 2009, 03:11:59 PM »
I think that Dave Silver still lists these kits. May be worth a look.
Cheers
Seamus
Offline Seamus
« Reply #11 on: November 27, 2009, 03:35:39 PM »
Apologies, I was looking at the tool kit, not the tray.
If it helps, my 1970 (12/70) K1 has a steel tray.
These people seem to be breaking a 71 CB750 (from ebay, search CB750 1971)
http://myworld.ebay.co.uk/hyabusa010/
Cheers
Seamus
Offline Johnie
« Reply #12 on: November 27, 2009, 04:00:22 PM »
Depending on how original you want to go with the tool bag for that K1, the OEM tool bag is the black padded one with HONDA melted into the side. The blue bag is for newer years. Took me a bit to find that bag in good condition, but they are around.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #13 on: November 27, 2009, 07:25:52 PM »
The axle wrench is a 2 holer..on K! and earlier
The kit shown may be missing as many as 4 pcs.
There are a few part in the partsbook 9up to K1), that I HAVE NEVER laid my eyes on in 3 decades of owning a Honda 4... :o
 2 feeler guages for the valves
 A lever, it looks like a warding file with a slot in it (I cant figure out it use, except maybe to brake screws loose if it fits the bits?)
 Points file
