Author Topic: Here's The Specs On The Shelby Charger, For Those Who Might Be Interested.  (Read 1977 times)
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
  This is pretty lengthy reading. Hope you all enjoy. :)
   I'm certainly ENJOYING driving this one! 8) ;)
    Okay, I said I'm post what I knew about the Lil' Shelby Charger that I picked up on and here's what I know as of now:
(this is what I was told)
Suspension:
1. KYB Struts & Strut Mounts in the front & rear
2. New Shelby Front Springs
3. Rear Disc Brakes from an 87' Shelby Daytona Z
4. Mopar Performance Rear Sway Bar
5. 87' Daytona Shelby Z wheels 15" x 6"
6. Daytona Shelby Z Front Sway Bar 1 1/4"
7. All New Bushings
8. Rebuilt Rack and Pinion
9. New Outer Tie Rod ends
10. New Front Brake Calipers, Rotors & Hoses
11. 205/50/15 Cooper Zeion Tires
Transmission:
1. A555 Trans From 87' Daytona Shelby Z
2. Shifter & Cables From 87' Daytona Shelby Z
3. Differential locker unit
4. H.P. Axle Shafts from Forward Motion
5. New Street Disc & Stronger Performance Pressure Plate
6. New Trans Mounts
7. New Findanza Aluminum Flywheel
8. New Custom 6 Puc Clutch (with car, in a box)
Engine:
1. New Custom Intercooler from a 2003 Dodge SRT4
2. New Engine Mounts
3. New Ported 58mm Throttle Body
4. New 475 Cam from Forward Motion
5. New High RPM lifters
6. 87' Daytona Shelby Z High Swirl Ported & Polished Head
7. New Ported Exhaust Manifold
8. Block has been "O-ringed"
9. New Radiator
10. Shelby T2 2 Piece Ported and PolishedIntake Manifold
11. New Mopar Performance Stainless Steel 2mm Larger Intake & Exhaust
Valves
12. New Mopar Performance Springs & Titanium Retainers
13. Powder Coated Valve Cover
14. New Custom Forged Steel Rods
15. New Custom Forged Steel Crankshaft
16. New Custom Forged Aluminum Pistons
17. New Oil Pump
18. New Enforcer 2 Turbo From Forward Motion
19. New Cold Air Hose & K & N Filter
20. New Oil Catch Can
21. New Oil & Coolant Lines At Turbo
22. New ARP Head & Main Studs
23. New ARP Rod Bolts
24. New Evaporator
25. New Heater Core
26. New Fuel Rail
27. New Fuel Injectors Mopar Performance P/N 4452804
28. New Fuel Pressure Regulator
29. New Inline Mopar Performance Super 60 300 LPH Fuel Pump
30. New Shelby Stage 2 Computer
31. New Water Pump
32. New Hi Amp Alternator (Later model and it has been wired to a
standard Mopar voltage regulator, instead of to the computer like the
stock one was) "Nice Touch"
33. New Findanza Underdrive Pulley from Forward Motion
34. New Findanza Custom made Adjustable Cam Gear
35. New Hardened Followers
36. New Mopar Perfpormance Valve Keepers
37. New Greddy Type S Blowoff Valve
38. Power Steering Pump Is Factory Original, But Rebuilt with New Seals
Exhaust:
1. Ported 2.5" Exhaust O2 Housing
2. New Custom 3" Down Pipe 32' Long To 2.5" over Axle Pipe Into new
DynoMax Muffler with New Stainless Steel Tip
Extras:
1. New Audiometer Exhaust Temp Gauge
2. New Audiometer 20lb Boost Gauge
3. New Audiometer Tach
4. New Audiometer Air/Fuel Gauge
5. New Blitz Turbo Timer
6. New Kenwood Stereo (June 2009)
7. New 6 x 9 Speakers In the Rear (also June 2009)
8. New Optima Battery (installed 1 Dec2009)
9. Fire Extinguisher
Folks, this little Shelby Charger will REALLY MOVE, when you get into
it!
Member # 1969
Offline bucky katt
  • i am a pastafarian!
    • facebook
Re: Here's The Specs On The Shelby Charger, For Those Who Might Be Interested.
« Reply #1 on: December 06, 2009, 07:18:01 AM »
Bill, do yourself a BIG favor and see if heavy duty motor and trans mounts are still available for it. i remember the stock mounts being a bit problematic when these cars are thrashed hard.
Mark Twain - Notebook, 1894
Offline bill440cars
« Reply #2 on: December 06, 2009, 11:39:29 AM »
    I'll do that Jeff. He DID throw in a few EXTRA parts AND Mounts were part of that. 8)
                                     Have A Good One Jeff, Bill ;)
Member # 1969
Offline bucky katt
    • facebook
« Reply #3 on: December 06, 2009, 11:43:03 AM »
thats one of my favourite cars of all time Bill, they surprised ALOT of mustang and camaro owners back then.
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
« Reply #4 on: December 06, 2009, 12:15:18 PM »
I had one of those way back in the day, Mine had the high-perf shelby motor too.  It was a fun car, but in the end it ws a typical chrysler product..  These days I'll stick to my impreza.
I like berries.
Offline Ecosse
  • Member #4139
    • My 550 walk around video
« Reply #5 on: December 06, 2009, 12:20:16 PM »
for a while direct connection (ok, mopar performance) sold a dohc kit for these and 300 hp was sited.
remember the spirit r/t? the prototype reached 300 hp but then they weren't able to harness it to fwd.
i love these too bucky! i had an '85 glh... not intercooled, and loved that crude lil' beast. i miss it.
oooh, careful with the 'typical chrysler' stuff gsx, you're in the mopar den.  ;D
1974 CB550K
                                  Your 1%er name
Offline bucky katt
    • facebook
« Reply #6 on: December 06, 2009, 12:22:11 PM »
i can still remember the commercial for the omni glh like it was yesterday.
Offline Ecosse
  • Member #4139
« Reply #7 on: December 06, 2009, 02:08:51 PM »
this wasn't the one i was looking for but it brings back memories. remember the 024?
1974 CB550K
                                  Your 1%er name
Offline bill440cars
« Reply #8 on: December 06, 2009, 03:20:06 PM »
        Hey Bill, THIS one Still Blows off some of the newer Mustangs! Said to be putting out about 245hp and if I can find a place with a dyno AND someone who knows Turbo cars, it can be dialed in to give 300hp. 8) I guarantee you that, when you stick your foot in it, KIT GOES! The seller said that it is equalivalent to the Shelby GLHS Charger.
AND, it still has an A/C that will freeze you out, along with a nice Kenwood Stereo that puts out great sounds of it's own! ;)
Member # 1969
Offline bucky katt
    • facebook
« Reply #9 on: December 06, 2009, 04:04:37 PM »
theres NOTHING at all like a boost ride. i wonder if i could turbo the saturn...................  :D
Offline bill440cars
« Reply #10 on: December 06, 2009, 05:35:41 PM »
        Careful Jeff, when "The Bug" bites, It Bites HARD! :D ;)
Member # 1969
Offline bucky katt
    • facebook
« Reply #11 on: December 06, 2009, 06:35:07 PM »
i'd actually love to build another turbo air cooled bug. i still have most of the turbo system off of the 65 bug i had years ago. all i'd need to do would be to rebuild the turbo and weld up a new exhaust pipe for it.
Offline bill440cars
« Reply #12 on: December 06, 2009, 08:18:49 PM »
           Sounds Cool Jeff. 8)
Member # 1969
Offline Hasenkopf
« Reply #13 on: December 06, 2009, 09:12:08 PM »
Hey now, don't get me wrong, I loved my car too,  it's just so much nicer to have an awd car that runs just as good as the charger.
I like berries.
Offline Ecosse
  • Member #4139
« Reply #14 on: December 07, 2009, 01:16:48 AM »
when mopar was toying with that 300 hp dohc they had a prototype awd and shelby got his hands on that too. mopar (remember they owned most of lambo) had another daytona with awd and... a lambo v8, and called it the decepione.
that's why chrysler kicked butt. them boys weren't right in the head.  ;D
1974 CB550K
                                  Your 1%er name
Offline bill440cars
« Reply #15 on: December 07, 2009, 04:08:01 AM »
                  Didn't remember the name but did remember the deal though. 8)
          Also had part of Maserati and built some Lebaron TCs (I think that's what they were called. There were a couple of them for sale in Arkansas on Craig's list for a bit (2dr convertibles that also came with porthole hardtops. Don't remember about the performance of those though. I CAN promise you one thing though, this Lil' Shelby that I picked up on, will Kick Butt's (with the performance like I've NEVER seen from an engine that looks like a regular little 2.2! :o 8) ;) Know this, my little 84' Turismo 2.2 with the 2 barrel carbed 2.2 (110hp) and 5sp was a pretty good little runner AND this one will easily run off and HIDE from that one! :o
« Last Edit: December 07, 2009, 04:11:15 AM by bill440cars »
Member # 1969
