Author Topic: Will a 76 cb750f cylinder fit on my 78 cb750f engine with no problems?  (Read 784 times)
Offline hapakev
  • Your Standard
I have taken apart my engine for a rebuild and want to replace the cylinders due to some broken fins.  There is otherwise nothing wrong with my cylinders, but I want them to look good.  I know that if I use a K head, some of the dowels and o-rings are different.  Is it feasible to use 75-76 cb750f or cb750k juggs?
Smoking Jack
1978 CB750F(ish)
Offline Old Scrambler
Re: Will a 76 cb750f cylinder fit on my 78 cb750f engine with no problems?
« Reply #1 on: January 05, 2010, 06:41:58 PM »
Your asking two things..........all 75-76 f units are interchangeble with k units.  The black 77-78 f jugs do not fit on k crank cases. The 77-78 f heads will fit on a k barrel with minor mods but the compression will be low if you use standard k or early f pistons.  The k head will fit on 77-78 f barrel with mods but the 77-78 f pistons will hit the exhaust valves.  They can be relieved to work but with high compression of 10 or more.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline hapakev
  • Your Standard
« Reply #2 on: January 06, 2010, 07:47:08 AM »
OK thanks, thats what I wanted to know.  Only the "78F" juggs will work on the 78F motor, without modification.
Smoking Jack
1978 CB750F(ish)
