Author Topic: Testing the Vinegar Tank treatment...  (Read 20114 times)
Offline Colonel
  • 750K5
« on: January 30, 2010, 07:40:56 PM »
I am doing it... Will let you know...
Offline Gordon
  • 750K1, 550K2
Re: Testing the Vinegar Tank treatment...
« Reply #1 on: January 30, 2010, 07:52:07 PM »
I have no doubt it will work fine since it's acidic.  Weak acids just take longer, but not everybody's in a hurry. :)
Even just using vinegar I'd remove the petcock first.  Acid eats aluminum.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #2 on: January 30, 2010, 09:03:15 PM »
And produces hydrogen- BANG!
Offline Colonel
  • 750K5
« Reply #3 on: January 31, 2010, 10:08:25 AM »
Petcock is out... Plugged the tank with a custom "French Bordeaux" cork...
Sat the tank on top of a large plastic bin...
Vinegar in...
Offline wardenerd
  • '77 550F '81 650C
« Reply #4 on: January 31, 2010, 10:11:50 AM »
PO on my bike cleaned the tank with a kit and never removed the petcock.. Did I tell you that petcocks are about$70
Online Don R
« Reply #5 on: January 31, 2010, 10:30:56 AM »
The guy that bought my brothers yamaha 1100 used "the works" and blew the tank up. He most likely left the petcock on.
« Reply #6 on: January 31, 2010, 11:05:38 AM »
Vinegar in...
That Cork my be the key to success. I am interested to see how this turns out.
Offline HondanutRider
« Reply #7 on: February 01, 2010, 06:07:02 AM »
Using a cork or something similar to plug the petcock holes may be a good idea if you use a weak acid like vinegar.  I've used several layers of electrical tape to seal over my tank holes, and that worked good to seal and didn't damage the paint when removed.  The electrical tape also didn't seem to be affected by any acid that I used.  I'd be afraid of cork getting "eaten" by something stronger than vinegar.
« Last Edit: February 01, 2010, 06:10:14 AM by HondanutRider »
Offline xenoscr
  • 1975 Honda CB750 K5
« Reply #8 on: February 01, 2010, 06:53:34 AM »
There are science supply stores online that sell rubber stoppers for test tubes that work perfectly for sealing the holes from the petcock. Just measure the holes and order the right size. They have two measurements, top and bottom diameter. This is what I ended up doing when I used a Kreem kit to clean and seal my tank. It held well even with a full tank of cleaner inside.
XenosCR
1975 Honda CB750 K5
Offline mystic_1
  • 1970 CB750K
« Reply #9 on: February 01, 2010, 07:20:01 AM »
What concentration of vinegar are you using?
mystic_1
- John Augustus Shedd
Offline Popwood
« Reply #10 on: February 01, 2010, 10:40:15 AM »
If your local hardware store has the rows of boxes from Hillman Fasteners, usually found above the bins of screws, washers, nuts, etc., you'll probably find a nice variety of rubber stoppers. I've been working on my tank and bought two, one for the petcock opening and a wide one for the gas cap opening. The small one was 49 cents, the large one $3. It's kept the acetone in while I was cleaning residual gas varnish and the electrolyte solution when I did the electrolysis treatment (worked great!!) and the glass bead abrasive out while blasting the old paint off.
Current Rides:
1975 cb550K
1975 cb750K
1967 Bridgestone 350GTR
Past Rides:
1988 400 Hawk
195? Schwinn Whizzer
Offline Gnat
« Reply #11 on: February 01, 2010, 10:51:23 AM »
Home depot carries rubber stoppers in a variety of sizes (they almost carry everything) I used wooden dowels that I thinned and screwed them into the holes
Gnat
"Trying to keep the rubber side down"
Offline Colonel
  • 750K5
« Reply #12 on: February 03, 2010, 10:49:49 AM »
mystic_1
I filled my tank with White Vinegar - the kind you by by gallon @ your grocery store -; left the cap unlocked. In the evening I clean the rust depot from the tank cap with a cloth.
The process is slow but the metal is now showing...
I know I should have taken a pic of before... But I will take some shots tonight.
I will probably drain the tank in the coming days, rinse with hot water several time (baking soda?) then flash the tank with rubbing alcohol to get rid of the water.
Let me know if I should look into something else... This is my first vinegar treatment...
Offline Popwood
« Reply #13 on: February 03, 2010, 10:59:06 AM »
Someone pointed out rubbing alcohol is about 60% water-- maybe more, so not the most effective water removal solution. I recently did this and used acetone, which was the suggested alternative. I got as much of the water removed as possible-- vigorous shaking, then added a small can full of acetone, probably a pint container. Shook this around. Did the trick.
Current Rides:
1975 cb550K
1975 cb750K
Past Rides:
1988 400 Hawk
Offline lone*X
« Reply #14 on: February 03, 2010, 11:27:21 AM »
You can get higher percentage alcohol.  I have some that is 90% that came from Walgreens.  Also you can buy straight isopropal alcohol at the hardware store by the gallon.  Acetone flashes much more readily than alcohol so be careful with it, particularly in a closed garage.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline xenoscr
« Reply #15 on: February 03, 2010, 12:48:54 PM »
It'll also eat your paint. If you don't plan on repainting, be careful.
XenosCR
1975 Honda CB750 K5
Offline lone*X
« Reply #16 on: February 03, 2010, 01:58:04 PM »
As a side note to this thread, a few weeks ago one of the segments of Horsepower TV on the SPIKE network ran a demo of using vinegar as a rust remover.  They showed an example of a rusty plate that they half way submerged in a dilute vinegar/water solution for a few days.  Submerged portion of plate was notably clear of scale and appeared clean.
Nice thing about vinegar is it is CHEAP, environmentally safe (put the leftovers on your salad), and you can't burn holes in your jeans with it.
Lone*X  ( Don )
75 CB550K1
« Reply #17 on: February 03, 2010, 02:16:28 PM »
One thing. No matter how you get the Vinegar out and dry the tank, you would probably want to coat the tank quickly with some sort of oil to prevent flash rusting.
Offline Colonel
  • 750K5
« Reply #18 on: February 06, 2010, 09:12:39 AM »
Here are some pictures of the experiment.
As mentioned before I did not take BEFORE but trus me when I say the inside of the tank had a lot of surface rust.
Note also the deposit of rust on the cap... It seems that Acetic acid is doing it's job.
Next, I will rinse and flash with 9o% alcohol, dry then flash with motor oil...
I am planning to re-install the tank right after oil treatment, then re-fill; Any comments?
Cheers, Stephen
« Reply #19 on: February 06, 2010, 10:17:02 AM »
Looks great and I think you hit on something here. I have a few specks inside my tank, so this looks like a nice way to clean it up without using harsh chemicals. Congratulations!
Offline cafenut
  • it dont hurt till the bone shows
« Reply #20 on: February 07, 2010, 09:03:43 AM »
i understand oiling the newly cleaned raw metal but what stops the rust from forming on the upper portion of a tank three quarters the way full?
88 1100 katana
84 500 ascott
78 750 f cafe
78 750 f original
78 750 k stock
76 750 k custom
76 750 k chop project
« Reply #21 on: February 07, 2010, 09:10:50 AM »
Gas is a bit oily and also forms some varnish which may seal the metal. Also the rust where the gas is drawn from like the sides and bottom may have more harmful effects.
Offline JoshuaJames
« Reply #22 on: March 16, 2012, 06:55:06 AM »
what is the best way to prevent flash rusting?
Brake cleaner, some gas, motor oil........
« Reply #23 on: March 16, 2012, 07:06:15 AM »
If you go the oil route use two stroke oil as it readily mixes with gas. Motor oil not so much. Maybe a little 2 stroke with gas,swish it around the bare metal,drain and close up the cap and tap. Flash rust can happen fast.
Offline Irukandji
« Reply #24 on: March 16, 2012, 08:49:38 AM »
I want to ask .... How  does the anti-flash treatment help when after you put in gas and use it up.
Wont the same metal be exposed and rust up anyway?
750k3
