Author Topic: Aftermarket Boge shocks  (Read 24058 times)
Re: Aftermarket Boge shocks
« Reply #50 on: January 12, 2006, 04:00:12 AM »
And a couple more...............
Offline cbjunkie
  • ...know what i'm sayin'?
« Reply #51 on: January 12, 2006, 08:10:32 AM »
those are smart looking shocks! i can't wait to get mine on...!
thanks for the narrative, terr - you're making me thirsty with that strongbow language, though. i am gonna have to try that out you make it sound so tasty!
1971 750K1
1972 CB350 (deceased)
sometimes naked, sometimes mad -
now the poet, now the fool -
thus they appear on earth,
the free men.
« Reply #52 on: January 12, 2006, 08:46:41 AM »
I'd say you probably smelled like french fries rather than a baked potato. Where was the oil coming from??? Boy, that original tank sure did let you down....those are some big bubbles. I'm very surprised you didn't break through the surface when you were sanding the tank for paint. As a side bar....straighten out those rear turnsignals for Christsakes!!  :D ;)
eldar
« Reply #53 on: January 12, 2006, 09:12:19 AM »
Well those look mighty nice. So I think I am going to try and score some here soon.
Thank you for your hard work and personal sacrifice! your leg should be ok since it did not get burned off right away by the oil!
« Reply #54 on: January 12, 2006, 01:44:16 PM »
Picky, picky, picky! Ha ha, well the engine will have to come out for some serious surgery Mike, have you got a good F2 head (not that such a thing ever came out of the factory.....) that you can "massage' for me? I made several errors (in hindsight, of course) when I originally rebuilt it, and so I will need to strip the engine completely to remediate these faults.
I need to strip the bottom end, due to using the incorrect sealant for the case flanges, (Loctite 515 rather than 518, although next time I'll use threebond, and damn the torpedoes!) I need to replace the "K" cylinder block with a proper F2 cylinder block due to oiling issues pointed out by Karl Gray a year or two ago, (where is Karl?) and this is probably the cause of the oil leak I experienced yesterday, the head is cause for concern aslo as there are too many "rattles" probably caused by worn out valve guides.
Finally, I need to repaint the top crankcase, as the industrial strength fuel additive that I used to take the moisture out of the tank and remove any rust (which it did so well it ate holes in my tank!) dribbled over the paintwork, immediately bubbling all my hard work! Oh well, wisdom in hindsight and all that, the trouble is that the "racer" project suffers every time my other bikes experience a set-back like this. Maybe I should dump the F2 engine in a dark corner of my garage and assemble the racer engine, and use the F2 as a "testbed" until I've finished the racer's frame mods? Hmmmnnnnn......... Cheers, Terry. ;D
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« Reply #55 on: January 12, 2006, 02:16:50 PM »
I feel alot better knowing an "expert" screwed up a topend job, and it just isn't dum me.  Miss torqued one head bolt and while pushing the engine hard popped the high pressure o-ring out the side.  Lots of smoke and a wet leg like a dog though it was a fire hydrent. ;D
Just send me the F2 and I'll fix it up so you can ride any time your in the Maritimes ;D, I'll keep it well riden when you not ;D
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
« Reply #56 on: January 12, 2006, 02:27:59 PM »
What's your shipping address? ;D
Offline clarkjh
  • Expert? If only.
« Reply #57 on: January 12, 2006, 02:39:51 PM »
I'm going to give it to you just as soon the the "Boss" gives me the money to buy one of you kits.  Can't afford the prices that Netscrounger charges for his on Ebay. ::) ;D ;D ;D
James
SOHC/4 #3328
« Reply #58 on: January 12, 2006, 02:44:51 PM »
James
There's one on Ebay at the moment James, going very cheap! The current high bid doesn't even cover material costs, boohoo! Take a walk on the wild side mate, that "Netscrounger" is a top bloke, and his Koolers are the coolest, ha ha! ;D
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=4602732994&rd=1&sspagename=STRK%3AMESE%3AIT&rd=1
Offline cbjunkie
« Reply #59 on: January 12, 2006, 02:45:55 PM »
you pulled in, what 215  last week, right?
1971 750K1
the free men.
« Reply #60 on: January 12, 2006, 02:50:29 PM »
And the rest mate, geez I don't switch the lathe on for less than 500, ha ha!.............. Allright, I'm full of #$%*, I sold one cooler then spent the money twice over on more parts I don't need, got ripped off on shipping, and the parts arrived damaged, boo hoo!.......... I am an Ebay-aholic! (feel sorry for me yet?)  ;D
« Reply #61 on: January 12, 2006, 02:55:12 PM »
Terry, I don't have an F2 head BUTTTTTT I just picked up a mint 78 K head that would work perfectly with the K barrels on the bike now. Oh....I forgot- you'd need an 836 kit too.  8) ;)
« Reply #62 on: January 12, 2006, 03:03:38 PM »
Hey Unky Mike, and I can use my F2 carbs and airbox with that k8 head too, yeah? What about the F2 cam? Tell me more, Head Scientist! ;D
« Reply #63 on: January 12, 2006, 03:12:37 PM »
Carbs and intake boots (insulators) are the same on the K8 and F2. I imagine the airbox is as well (Sean would know). I don't see why the F2 cam wouldn't work- it just has a little more lift. I'd put in a megacycle cam in the thing nephew. ;)
« Reply #64 on: January 12, 2006, 03:27:49 PM »
Sooo, what sort of $$$ are we talking for that tatty ol' head, Unky mike? I can't afford a big bore kit right now, but i've got a new 3rd oversize piston kit with new rings, wrist pins etc, so that might have to do me, but with the F2 cam it should go ok? Cheers, your favourite nephew, Terry. ;D
« Reply #65 on: January 12, 2006, 05:10:19 PM »
Let me take the valves out and check it over. I just got it yesterday. I assume you want a little port work too?? It would work OK with 3rd over pistons (as long as they are K pistons) and the F2 cam. I'll email you sir.
« Reply #66 on: January 12, 2006, 05:25:58 PM »
Thanks Mike! ;D
Offline Joe Danger
    • joedanger.us
« Reply #67 on: January 13, 2006, 01:30:35 PM »
Damn, I missed a hell of a sale!  Anyone trying to get rid of a pair?
77 CB550K  82 CX500C
« Reply #68 on: January 13, 2006, 01:48:03 PM »
Keep watching his auctions Joe, Tim (the seller) hass got 7 cases of 12 pairs left, so you'll get a pair, no worries! Cheers, Terry. ;D
Offline cbjunkie
« Reply #69 on: January 13, 2006, 02:26:04 PM »
he doesn't seem to have them posted yet, though...only the double-eye type up right now...
no luck getting him interested in selling direct, terr?
1971 750K1
the free men.
« Reply #70 on: January 13, 2006, 02:44:24 PM »
G'Day CBJ, just contact him mate, he'll sell you a pair for 50 bucks, and I wouldn't bother trying to haggle further, he knows he can sell them for 50, and 50 bucks is bloody cheap, geez, I might buy some more for future bikes, ha ha! Cheers, Terry (Ebay-aholic)  ;D
Offline cbjunkie
« Reply #71 on: January 13, 2006, 02:47:56 PM »
already got mine on the way, terr... ;)
good on ya, mate  8)
1971 750K1
the free men.
Offline clarkjh
  • Expert? If only.
« Reply #72 on: January 13, 2006, 05:58:52 PM »
I wounder how they work work of a 550 with bags on the back?
James
SOHC/4 #3328
« Reply #73 on: January 13, 2006, 06:12:19 PM »
Are you worried about extra weight or interference with the spring action?
There are three different weight springs available to compensate for extra poundage.
They don't have the spring shields that the Cb550s have prior to 77, so soft bags will need a "bag stay" to keep them from being pinched during the springing action.  However, one could argue that even with the spring shields, the soft bags shouldn't rest on the shocks anyway.  They still move around a bit and will rub and wear on each other.
Offline clarkjh
  • Expert? If only.
« Reply #74 on: January 13, 2006, 06:32:46 PM »
I have hard bags, (yes I left my self wide open for smart remarks) plus I would install the shields from my shocks, 74.  I only weigh 125lbs, but some of the computers I carry on the rack can go up to 200lbs.  That and we have some of the worst roads on the east coast.
James
SOHC/4 #3328
