Author Topic: Fix side cover cracks  (Read 2061 times)
Offline Big Cobra
« on: February 10, 2010, 06:04:08 PM »
anybody have any advice on how to repair cracks in a side cover?
Thanks
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
Re: Fix side cover cracks
« Reply #1 on: February 10, 2010, 06:05:56 PM »
there's a good thread on this somewhere, but as far as I remember, it involves using MEK and pieces of plastic as a brace on the back.
« Reply #2 on: February 11, 2010, 10:11:11 AM »
This works pretty well.
http://expertplasticwelding.com/
Seriously I used him great price and result.
If you want to DIY, there is/are a couple of great threads. Search "plastic welding" or some such.
Offline cb750k77
« Reply #3 on: February 11, 2010, 10:13:06 AM »
i used some fiberglass matting and a thin layer of resin worked really well but wear gloves it was messy! but its super strong! i like it and who ever see's the back side anyways!
CB750k77 rebuilt (almost)
Offline Raul CB750K1
« Reply #4 on: February 11, 2010, 11:28:21 AM »
Offline westondc
  • Wes Mantooth
« Reply #5 on: February 11, 2010, 11:41:18 AM »
JBWeld? i glue everthing with it.
B.O.X.N.I.F.E. Hospital fund https://www.everribbon.com/ribbon/view/8352
Rider no. 115 on the 2012 SOHC/4 Honda World Tour
Rider no. 274 on the 2011 SOHC/4 Honda World Tour
1972 Honda CB500k1
1971 Honda CB350k3
the project http://forums.sohc4.net/index.php?topic=64499.0
Trip/Project Blog http://easterntowestern.blogspot.com/
just be a vagabond, living out of a backpack on a little Honda, cruisin all over the damn place....
"As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?"
Offline dewjantim
« Reply #6 on: February 11, 2010, 12:10:24 PM »
That is how my painter did my CB550F side covers. They are strong and look perfect from the outside. JBWeld works well sometimes, but seems to pop off the part when the weather turns cold. My painter also tried the plastic welding method.... he didn't have any luck. From what I have seen, plastic welding is probably the best but it sure must take a hell of a lot of practice to get it right......
« Reply #7 on: February 11, 2010, 01:16:59 PM »
It seems that most adhesives don't bond well to these kinds of plastics, kind of like trying to glue something to a Teflon frying pan. The last time I did this type of repair, I sandblasted the repair area first, using coarse sand. It really roughed up the surface, giving something for the glue to hang on to. Then I used a few layers of fiberglass cloth, thoroughly impregnated with J B weld. Been over ten years and still holding. BTW, I DO NOT recommend the "quick" version, just the good old let-it-cure-24hrs stuff.
Offline domer
« Reply #8 on: February 11, 2010, 01:43:01 PM »
being as poor as i am, i pulled out the abs cement and purple primer... sets pretty quickly making it so i didnt have to try and clamp the 2 peices of cover together... then i flattened a bunch of heavy duty staples in the vice, layed them across the glued crack and held an old soldering iron to them untill they were buried/melted into the cover. the pic only shows 2, but i ended up doing it every inch or 2. its held up better than i thought, even had to remove them a dozen or so times with out any issues... oh i filled the outside with spot putty, sand, paint...voila.
Offline Really?
« Reply #9 on: February 11, 2010, 01:51:53 PM »
I have used the method and stuff on my bike in the link below many times since my plastic is brittle.  Never breaks where I fixed it, just outside of it, yanno, the brittle aged and weather beaten plastic.
http://www.angelfire.com/oz/tes/Plasticfix/PlasticFixSite.html
The VersaChem resin is awsome and is easily found at AutoZone, O'Reilly's and such.  The only recommendation I have for this stuff is do not buy too much becuase after about 6 onths on your garage, it is useless, even if unopened.  Well, it gets really hot in the garage during the summer.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline shizzomynizzo
  • It's 5 o'clock somewhere
« Reply #10 on: February 11, 2010, 02:35:39 PM »
JB bumper epair kit, comes with little mesh patch. The JB sand suprisingly smooth and can't tell it was done unless you look in the back. Cheap, quick, and permanent!
1974 CB550
1985 XLX Last of the IH
2001 Street Glide
Offline Nikkisixx
« Reply #11 on: February 11, 2010, 03:51:05 PM »
I vote fiberglass mat, on the whole doggone thing.  Tried to "weld it" only to have it break in another place.
Offline fmctm1sw
« Reply #12 on: February 11, 2010, 04:36:05 PM »
There's a post here where someone melted down a PVC pipe or something.
*edit* can't find it.  had photos too and mentioned cutting a "V" into it and pouring the solution into it..
« Last Edit: February 11, 2010, 04:48:53 PM by fmctm1sw »
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
