Author Topic: Measuring ring gap 750  (Read 1131 times)
Offline AshimotoK0
  • CB400/4, 69 CB750K0, '69 CB250SS, CB350K1 CB500K0
« on: February 17, 2010, 11:51:57 AM »
The Honda manual says "When only the ring is to be replaced without boring the cylider wear, the ring gap should be measured at the skirt of the bore"
What position is the 'skirt of the bore'
 Also if measuring bore wear with the piston in the bore (with no rings fitted), where do you insert the feeler?
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.”
Offline MJL
  • Don't listen to me, I'm no
Re: Measuring ring gap 750
« Reply #1 on: February 17, 2010, 12:02:07 PM »
The skirt is the every bottom where there is no wear. Fit the ring inside and slide a piston down against the ring to make sure it is square.
The second part, insert the feeler between the piston and wall of the cylinder. I've never done it, but I would think you need narrower feelers to get an accurate measurement.
Offline markb
  • When I finish my current project I might be a
« Reply #2 on: February 17, 2010, 12:11:31 PM »
Actually you insert the feeler gage between the ends of the ring, in the gap (with the piston out).
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: February 17, 2010, 12:25:29 PM »
That's for measuring ring end-gap, not for measuring piston-to-cylinder clearance.
mystic_1
- John Augustus Shedd
Offline markb
« Reply #4 on: February 17, 2010, 12:32:38 PM »
Ooops, I got it.  Just reading too fast.
Offline AshimotoK0
« Reply #5 on: February 17, 2010, 12:38:50 PM »
I do have a fancy bore gauge (gage) but getting used to using it is new to me so I am 'cross checking'
