Author Topic: removing sprocket from the hub...help needed  (Read 1210 times)
Offline Gnat
« on: March 31, 2010, 06:05:25 AM »
just how do you get the sprocket off. I've whacked it and cursed but that didn't help ;D. I thought it would come loose after I removed the side plate #3 in the drawing but now I see that the bolts are inserted in some other parts.
How do you do it???????
Gnat
"Trying to keep the rubber side down"
Offline wingman
Re: removing sprocket from the hub...help needed
« Reply #1 on: March 31, 2010, 06:08:29 AM »
I recommend more whacking and cursing.  Problem is that it is not supposed to be easy to get the sprocket out for obvious reasons.  Not to sound like a jerk, but did you remove the circlip (part number 11 or 17 - my eyes aren't so good).  If not, pull it off and continue with cursing and whacking.
1972 CB350F - Who needs TV?  I have a motorcycle in my living room! http://forums.sohc4.net/index.php?topic=67528.0
Offline Gnat
« Reply #2 on: March 31, 2010, 06:26:00 AM »
Yeah I'll look at the circlip didn't think it was involved...but with my luck that would be why.
Gnat
Offline Gnat
« Reply #3 on: March 31, 2010, 06:32:20 AM »
Also..if it is the case that the circlip is holding it in and its still tight should I use a gear puller to remove or is something threaded that I can't see?
TIA
Offline wingman
« Reply #4 on: March 31, 2010, 10:38:52 AM »
You should be able to remove with with a pair of circlip pliers - I got my at autozone for like $10.00.  Work on these bikes enough and the circlip will become the bane of your existence.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #5 on: March 31, 2010, 10:45:52 AM »
I have found many a use for my circlip pliers, had no idea I would use it as much as I do on these bikes.
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #6 on: March 31, 2010, 10:46:49 AM »
the circlip has nothing to do with holding the sprocket on, look closely and you'll see that it's for holding the bearing retainer in, it's smaller than the ID of the hole in the sprocket
Mark Twain - Notebook, 1894
Offline Johnie
« Reply #7 on: March 31, 2010, 10:56:29 AM »
Try a little PB Blaster around the area where the sprocket hits the hub. I never had an issue with removing the sprocket on these old bikes. Maybe the pic will give you a little visual. Don't let the nuts on the bolts confuse you. I just put those back on to keep the studs from falling out the back.
« Last Edit: March 31, 2010, 11:01:51 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
