Author Topic: Piston domes and airflow.  (Read 2866 times)
Offline Soos
« on: April 04, 2010, 11:58:59 AM »
Hey all,
1st Q:
How much will valve pockets shrouds affect airflow?
(see pics for with and without differences)
I am doing a bit of piston cleanups, and finally took a few minutes for a set of 66mm pistons I have.
I have 2 sets of these 66mm pistons, and since the higher dome set has 2 unusable pistons(cracked skirts) I would start with those 2.
The first one I did I did minimal cleanup.
The second one I got rid of the shroud of aluminum left from the valve pockets.
If you are wondering, these are KZ750 pistons modified for cb650 use.
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline mlinder
  • "Kitten Puncher"
  • Moderator
  • Stop Global Tilting now!
    • Moto Northwest
Re: Piston domes and airflow.
« Reply #1 on: April 04, 2010, 01:13:23 PM »
What do you mean, "air flow"?
No.
Kurlon
« Reply #2 on: April 04, 2010, 01:55:23 PM »
I 'suspect' the impact isn't that great?  Looking at 'high perf' pistons for say, 2v Ducatis they don't clean up the valve pocket shrouding.
http://www.ducshop.com/product_view.php?cat=6&pid=297 as an example.
Offline Franken750
  • Adventia b4 Dementia
« Reply #3 on: April 04, 2010, 11:41:53 PM »
Soos,
Domed pistons really are awful things, but were a product of engine evolution of the time.
Firstly: a high-domed piston has much larger surface area than a flat-top piston.
This means much more heat can be absorbed by the piston (= higher oil temp = burned oil around rings, wrist pins = poorer lubrication at the top of the bore). The heat loss also reduces the cylinder combustion pressure.
Secondly:  Extra metal in the dome = heavier = more reciprocating mass = slower engine acceleration.
Thirdly:  To get ever-higher compression ratios the dome must push well into the roof of the combustion chamber. As in your pics, valve pockets are needed.
During overlap on the exhaust stroke is when scavenging is most needed, and is most efficient when you can see through the open exhaust valve and past the open inlet valve. You can't do that with high domed pistons. :(   Then there is the issue of the valve pockets interfering with good swirl patterns.
4-valve heads were the only way to solve all these problems. The XL-250 is a good example.
By contrast, the h.c. pistons used in the BSA and Triumph triples at Daytona  '69, '70 era are real shockers. I have a pic around here somewhere ...
Fourthly: Don't go carving bits off your piston willy-nilly, as it will upset the balance of the motor.  Pistons are manufactured to a weight tolerance of less than a gram, and also must all be the same weight.  :'(
Fifthly: No number fifthly.  :D
In among all that I think I may have answered your query.
Oh yeah - piston crowns can now be ceramic coated to provide heat insulation (= lower piston temps).
1982 Bol D'or CB750
1973 CB750 K3 in bitz in the Franken Lab.
1989 Porsche 928 S4
« Reply #4 on: April 05, 2010, 12:03:35 AM »
Soos,
This was one of the problems with Mopar Hemis; the extreme dome of the pistons were a huge heat sink.
I have to give it to you Aussies; you boys all seem to be pretty sharp!!!
Scott
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #5 on: April 05, 2010, 12:18:49 AM »
all that noted... the stock 650 gives the stock 750 a good run for it's money, and the only other notable difference is a much-improved port design... though to be fair this probably accounts for most of its power.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
« Reply #6 on: April 05, 2010, 12:29:56 AM »
Well, as the old saying goes, "the horsepower is in the heads". The more air a motor pumps, the greater the potential to make power..
Offline Franken750
« Reply #7 on: April 05, 2010, 12:32:51 AM »
Awww gee Scottly... Blush.  #-)
(As if we'd let anyone else think otherwise).
 ;D
Franken
1982 Bol D'or CB750
1989 Porsche 928 S4
Offline turboguzzi
« Reply #8 on: April 05, 2010, 05:11:12 AM »
I would ask it as in: " how much do deep pockets slow the swirl flow", surely not intake flow as the piston is going AWAY from the head at intake, so cant see how the dome has anythign to do with it.
But when the piston is at TDC, then it might slow down swirl and I hope we all agree that swirl is beneficial right?
So in high dome pistons my gut feeling is deep pockets hurt quite a bit. There is an old school car tuner who has a site (forgot his name) and he chamfers the sharp edges of the valve pocket cuts with a big 45 chamfer, specially on those tall hemi jugs.
Makes a lot of sense to me.
TG
Offline Soos
« Reply #9 on: April 06, 2010, 03:23:13 PM »
Thnx all.
And Ceramic coating is something I am interested in.
I do know that the flat top pistons of more modern bikes are like that for a reason(heat being #1) But for the bike I have, this is simply one of the options I have for an overbore.
The pistons are fairly cheap($30-$60/set) and I can do my own machine work(lathe and milling work)
I think I am going with the one with the valve pocket shroud material removed.
Just a few program changes. instead of manually cutting it off.
The less reciprocating mass with this big of an overbore sounds like more a reason than the flow it sounds like to me.
l8r
-=≡ Soos ≡=-
Offline mlinder
  • "Kitten Puncher"
  • Moderator
    • Moto Northwest
« Reply #10 on: April 06, 2010, 03:37:51 PM »
The pockets don't really affect flow, soos... I'm wondering if you are talking about something else..
No.
Offline vintage_racer
« Reply #11 on: April 07, 2010, 11:16:48 AM »
High doms are the real problem, the deep valve pockets are just a result of these high doms and probably don't hurt flow that much. The motor I raced with over the past 6 seasons had Yosh pistons with lots of dom and deep valve pockets (also used a pretty radical camshaft). For this season I'm building a motor with flat (stock) pistons and much more relaxed camshaft (just got it back from WebCam). I still keep my lightly ported head and CB750 carbs. We will find out if there is much difference in power between the two (I suspect that there wouldn't be much).
Dan
Ride that old SOHC hard
