When I tried turning the cam using the bolt at the ignition end of the shaft, all I did was loosen the bolt. It holds two washers at the end. I tried using the kickstarter but all it does is move the whole engine around because I don't have anything to fasten the engine to. Do I have to build some kind of engine stand so that I can bolt the engine to it to kick the starter to turn the cam? I can't believe nobody else has had this problem. I'm thinking about doing every other step in the shop manual so I can get the bloody head off.
I guess we should confirm what you are working on. I'm assuming CB750?
What you describe trying to turn is unknown to me. There is a large nut , not bolt, about 17mm or so. It is so designed that it will not loosen upon turning it in either direction as it is held on to the ignition drive stud with a 6mm (10mm head) nut. it is there for the sole purpose of turning the crankshaft for tune up and disassembly duties.
Lets clean up the context, which bike, etc.
Rereading your post, are you on the camshaft or the ignition end of the CRANKSHAFT? The crank is where you should be. Turning it will turn the cam.
