Hey toycollector10,
In my particular case, I have found that the best gas additive for me has been a product called SeaFoam. It is used considerably by marine boats and any gasoline engine users for removing and preventing rust. When poured straight into the gas tank, it will clean fuel injectors and carb fuel jets, removes all moisture. You can put it in your crankcase oil and it will clean dirty parts and increases RPM vacuum and compression.
I don't know if it is available in your area, but it is well worth searching for. It has been made since the late 1940s. It Removed rust from my gas tank with the first use, and has kept it clean since then. It comes in a 16oz. can and you use like about 3 to 4 ounces on first application, but you can go up to 8 oz. on first application if you want to. It has beat anything else I have ever tried.
~ ~ ~ jaknight ~ ~ ~
