Author Topic: engine sprocket noise , wobble  (Read 630 times)
Offline grwmotocycles
« on: May 19, 2010, 02:56:51 PM »
Finishing the 74 750 chop, had the engine running with no chain on and as I shift through the gears there is a rattle from the sprocket area. Shut it down and checked and the sprocket does wobble.  My 78 I just finished did the same (wobble) do not remember if it made noise. Common??????  Held a wood wedge against the sprocket and it calmed down the noise.  Need input, Geno 8)
Offline bistromath
Re: engine sprocket noise , wobble
« Reply #1 on: May 19, 2010, 03:01:56 PM »
Don't worry about it. There's normally some axial play in the drive sprocket.
'75 CB550F
