Author Topic: are 69-75 CB750 calipers universal?  (Read 2685 times)
Offline turninwheels
« on: May 28, 2010, 08:35:21 AM »
So i need to get a used caliper, but needed to ask about them being universal...also, is 550, or 400 CB claipers universal?...Thanks
"high powered suicide machine."
akershsa
Re: are 69-75 CB750 calipers universal?
« Reply #1 on: May 28, 2010, 03:09:54 PM »
   Almost all sohc fours had the "same" caliper,early 750's were not black,k0/k1 69/78K calipers will all work  :)
« Reply #2 on: May 28, 2010, 09:43:57 PM »
77/78 are a different looking smooth caliper with its own thicker swing bracket. Bleeder and inlet are at 12 oclock, and brake line angles outward..
 The other calipers have 2 brackets, 69 -72 and 73-76..
« Last Edit: May 28, 2010, 09:56:06 PM by 754 »
« Reply #3 on: May 28, 2010, 09:46:38 PM »
All of the '69-'75 calipers will fit all the '69-'75 caliper arms from every year, despite cosmetic differences like fins and ribs. The mounts all interchange, too, although they don't look like it until you actually bolt them in place.  :)
« Last Edit: May 30, 2010, 08:23:05 AM by HondaMan »
« Reply #4 on: May 28, 2010, 09:53:55 PM »
I disagree on the mounts: I have K7 forks, and there is no way that my earlier caliper mounts, that were on my K1 forks, will bolt up to the legs. I looked at this again, just this afternoon.
Offline myhondas
  • Not really such a
« Reply #5 on: May 28, 2010, 09:57:26 PM »
You didn't read the post....Mark stated K0-K5 were the same...you have K7....
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
« Reply #6 on: May 28, 2010, 09:57:40 PM »
True: the F1-K8 disc calipers are different. I'm referring to the K0-K6 ('69-'75 models).  ;)
« Reply #7 on: May 28, 2010, 10:02:39 PM »
Thanks. When did they change to the two-piece mount; the type with the bolt hole in the steel pin, and the aluminum top piece with two bolt holes? (I need one :()
« Reply #8 on: May 28, 2010, 10:05:20 PM »
Ooops!!! Sorry, Mark :-[
« Reply #9 on: May 28, 2010, 10:15:26 PM »
 The 3 hole mount came out in 73.. along with new fork tubes, that allow seal changes with forks in trees, and a little fender for the brake disc.
 The 3 hole mount is cleaner and far easier to work with.. iMO..
« Reply #10 on: May 28, 2010, 10:23:40 PM »
OK, now I'm confused, again. The mounts on the K1 were 3 holes, in an aluminum piece, with a steel pin to connect the caliper swing-arm. The K7 has an aluminum piece, with two holes, and a steel pin with one bolt hole at the bottom.
« Reply #11 on: May 28, 2010, 10:42:08 PM »
 What I mean is 3 holes only, on the brake hanger, the T shaped one as opposed to the C shaped earlier style that had an extra bolt for the brake line and different fender mounts..
« Reply #12 on: May 28, 2010, 10:48:42 PM »
Yeah, I need the T shaped type. So these appeared in 73??
« Reply #13 on: May 28, 2010, 11:00:12 PM »
 Correct.. maybe late 72.
 All fatstripers should have T type, cept A model and F
« Reply #14 on: May 29, 2010, 10:52:33 AM »
Thanks everyone!...going to Honda Steve's bone yard today...I appreciate this forum so much!...Cheers
Offline Ricky_Racer
« Reply #15 on: May 29, 2010, 02:21:37 PM »
Frank, what's the difference in the calipers/mounts between the A and the K3-6?  With the exception of the A's longer fork length and air adjust they look the same to me...  ???   RR
Offline nippon
    • Classic Cycle City
« Reply #16 on: May 29, 2010, 02:59:57 PM »
Offline Ricky_Racer
« Reply #17 on: May 29, 2010, 04:02:54 PM »
Interesting information, Nippon. Thanks! But my question was regarding the Automatic front caliper vs. the K3-6 and how they differed. I'm trying to determine swapability between mid-K's, Automatics, and late 550's. And no, I haven't checked the parts books yet on these particular parts.
I have determined that the F2 rear caliper is the same as the F2 right front caliper, and that the DOHC dual puck calipers with mounts will fit the K7-8 forks, but I'm still figuring out some of the other usable combinations. But thanks again.  RR
« Reply #18 on: May 29, 2010, 09:06:19 PM »
76 A had the hard-cromed forks before the 77/78 came out with them, and I believe late style smooth  caliper and hanger.. as far as I know..
Offline Hon3ybadger
  • Someday it will run...
« Reply #19 on: March 21, 2014, 02:18:42 PM »
So I have a 76 750F. I have the Hard chromed forks you say the Auto has. And my calipers are the feed and bleed at 12 o'clock high. Am I limited to 75 and 76 F and A for matching duals?
