Author Topic: Cb350f problems  (Read 670 times)
Offline Jarhead12
Cb350f problems
« on: May 30, 2010, 03:03:17 PM »
So i got a 74 cb350f. i have it running but the battery eventually died. Also it only runs with the choke half open. When i'm running the bike normal should it be run with the choke open or closed?? Also when i give it gas it almost dies. Is it not getting enough fuel. I just put a new carb rebuild kit in. Also my clutch is very hard to pull and my front brake rubs and i can't fix these. any ideas ???
Offline Gordon
  • 750K1, 550K2
Re: Cb350f problems
« Reply #1 on: May 30, 2010, 05:01:03 PM »
Sounds like you have a few or more fairly basic problems.  My suggestion is to get a good manual and start going through every regular maintenance procedure.  If you're still having any problems after doing that, then it's time to start looking for the causes.
Offline Jarhead12
Re: Cb350f problems
« Reply #2 on: May 30, 2010, 07:58:17 PM »
alright start that long process. I did get it started and idle find and then rode it. Front brake still rubs a little
