Author Topic: CB550 tire recommendations?  (Read 4968 times)
Offline harisuluv
« on: June 04, 2010, 03:36:00 AM »
I am to the point now where I need to be getting tires for my build.
My bike is a 78 cb550.  I don't really want old school tires and am looking for something modern.  I would also like something a little wider, specifically for my rear tire.  I don't want el cheapo tires either.  I've seen a lot of cool looking tires on builds here but I can't tell what they are!  Recommendations please, thanks in advance.
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
Re: CB550 tire recommendations?
« Reply #1 on: June 04, 2010, 03:51:30 AM »
Bridgestone Battlax BT45 still come in imperial size for the front 3.25x19 & 110/90/18 for the rear. Rear is dual compound.
If you have a search on this forum you will find lots of advice not to go bigger on standard rims. Good luck with your choice, I'm sure there will be lots more suggestions.  ;)
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
« Reply #2 on: June 04, 2010, 04:21:40 AM »
hey im with frosty here,use the stock width though,all you do with a wider tyre on a stock rim is wear out the centre faster,and comprimise your lean angles,im running a bt45 on the front and a spitfire on the rear,if im keen i scrape both pegs,i did have a bt45 rear but went spitfire when it was changed,i like the solid centre tread,i also have alloy "sun rims"i like my skinny rear tyre.
Offline Tom in Newcastle......Ontario
  • Newcastle Ontario
« Reply #3 on: June 04, 2010, 05:57:11 AM »
I have a stock 78 550k (My avatar).....and I am running Avon road riders,sizes ..  4.00-18 and 3.25-19
Don't know where you are ,but around here we have alot of Tar snakes and the Roadriders do not get affected by them ..
I think it is because of the non ribbed front,and the broken up center tread
1978 cb 550k......stock,my first re-build
Loud pipes suck.......
If you buy something.........pay for it !
If you sell something .......ship it !
If you say you are going to do something......do it !
If you have a question about something......ask it !
When the seller answers ........let him know whether you still want it or not !
If you receive something .....let the seller know you got it !
If you get something and are happy/un happy with it .....let the giver/seller know !
If you have any kind of issue,shipping/receiving/quality/price/shipping charges etc !
Communicate
Offline Fred T
« Reply #4 on: June 04, 2010, 05:58:12 AM »
Avon Roadrider, Bridgestone Batlax, Metzeller Lazertek, or Continentals.
I´m using the Avons on my CB 400 F and they perform very well in wet or dry conditions, good grip.
Offline IndyFour
« Reply #5 on: June 04, 2010, 06:16:43 AM »
I went with modern size tires simply due to availability and price.  I've been happy with the Dunlop D404 tires I have been running since last summer.  Used the conversion chart on this website to get appropriate sizing.  Nice a grippy and seem to handle well.  If it rains, I don't ride.....so I can't attest to handling in rain, but I've heard from others that they do well in that respect.
http://www.dunlopmotorcycle.com/tirecatalog_tire.asp?id=37
1974 CB550K
2000 VFR800FIY
__________________
Indianapolis, Indiana
Rlint
« Reply #6 on: June 04, 2010, 06:27:10 AM »
that conversion chart seems weird, as in it recommends 120 size for a smaller rear rim than 110 tires.  I'm not saying that I don't believe it, because I have no experience with it, but I don't understand the fact that wide tires wear out so much quicker.  Half of the modern tires are already rounded profile in the first place, and when you're talking the difference of 1cm between 90/90 and 100/90, which is less than four-tenths an inch, the difference in profile would be almost completely unnoticeable... I guess tires are touchy.
Offline fastbroshi
  • Puppet
« Reply #7 on: June 04, 2010, 07:01:10 AM »
  It's because if you put a wider rear tire on the same size rim, that wider tire has to be pinched more to fit, so it rounds it more and alters the shape it runs while you go down the road.  It gives it a higher peak in profile, so all the weight of the bike and rider is concentrated differently and this tire flattens out sooner.
  Like a running shoe, you know how the place where your foot contacts the sidewalk the most wears down faster.  As your sole wears, it alters how it feels while you're walking and REALLY worn shoes feel odd to walk in after a while.  Basketball players can really relate to this.
  If you were to take that same shoe and add rubber to it so you were just walking on that certain part that your foot wears the most, it would wear down real fast.  But since shoes normally have a relatively flat surface, they wear a bit more evenly.
Just call me Timmaaaaay!!!
Rlint
« Reply #8 on: June 04, 2010, 07:12:25 AM »
Yea, I understand the principle behind it, my point was that it seems like pinching something an extra centimeter would make a negligible difference, as it would alter the radius of the profile by probably a millimeter or so.
Offline jaguar
« Reply #9 on: June 04, 2010, 11:04:35 AM »
avons or dunlop gt501s
« Reply #10 on: June 04, 2010, 11:47:09 AM »
...when they are new.  Put a couple thousand miles on them and they loose their crown way more quickly than the stock sizes that properly fit the rim width.  That's when you start fighting the bars in turns to hold your line.
If you want modern tires put on modern rims first.
If you put a way large hat on your head, it may fit down around your ears and impede vision.
Offline haill
« Reply #11 on: June 04, 2010, 12:25:26 PM »
one has to also think that as the tire gets wider the side wall ratio goes along with it.  making the tire do it's job all that much harder. also increases the ride height, too wide and the centerstand becomes too short, which tells you something right there.
I've been considering replacing the  back with a 19 inch rim and running a 110/80-19 with a 90/90-19 front to get rid of some of the side wall thickness but stay close to the ratio.
« Last Edit: June 04, 2010, 02:11:02 PM by haill »
