Author Topic: CB750 still not running (pending).. what's the next step..  (Read 5184 times)
Offline oldhondarider
  • http://indimediaimages-shepdog.blogspot.com/
« on: July 02, 2010, 07:13:41 AM »
well.. crap... I bought a 75' 750f as a spare bike while I was rebuilding my 550.  It ran for a couple of days ( I know....the start of a bad story) then it wouldn't turn over and it mysteriously it developed a leak on the shifter side... SO I threw a blanket over her and marked it for another day to get to the problems.  Well....2 1/2 years later.... I'm getting to her..LOL
I changed the gasket on the shifter side...  that fixed the leak.
changed the oil filter, oil...etc..   kicked it 30 times to get the oil moving...
replaced the battery...
lights on...starter works...  but it still won't turn over.
tried kickstarting it.... no good
checked the plugs ( that #3 is a beeeaaachhh to get to) they're black and sooty.   ( is there an easy way to get to #3 and #2?)
pulled the tank and drained the gas..  looks very dark ( dark amber)...
Christ I just wanted a quick run around bike.... LOL..
Now it looks like I have to pull the carbs and clean them....  There goes some of my vacation... ;D
« Last Edit: July 12, 2010, 10:40:40 AM by oldhondarider »
"I have never seen a wild thing feel sorry for itself. A little bird will fall dead, frozen from a bough, without ever having felt sorry for itself."   D. H. Lawrence
Welsh Customs, Tacoma Washington
Re: damn... gonna have to start from the beginning
« Reply #1 on: July 02, 2010, 07:26:51 AM »
I'm looking for one of those too  ;D
I'm not TOO far north of ya!   I'll gladly take it off your hands.
Be sure to 'wash' the inside of your tank with some clean gas before completely filling it.
Have a fun 'cleaning' weekend, and remember...gas and fireworks dont mix  :D
« Reply #2 on: July 05, 2010, 09:05:38 AM »
hmmmm....
welll I pulled off the carbs...  no fuel in the 2 of the bowls... a little in the #1 and a little in the #4..  yellow/amber gas.
So I gave them the dip in Simple green, cleaned the bowls out.  I followed some advise and didn't pull the carbs apart..just let soak in simple green and the a good cleaning with carb cleaner.  I put it back to gether, w/ new hoses for the fuel lines to the bowls.  Replaced the air filter and reinstalled.
(BTW....getting the carbs on a 750 is a hella lot hard than on a 550.)
Still not running.
The starter works....just no kick over... I pulled off the #4 plug wire and jiggled it..the engine sputterd a bit but still no turn over..
Suggestions?  Should I buck up and pull the carbs completely apart?  or is there something else I'm missing.
What's the 3 things again....  Fuel delivery, Power delivery....and
Thanks in advance for your help.
« Last Edit: July 06, 2010, 06:50:32 AM by oldhondarider »
Offline Scott S
Re: Still not running.. what's the next step..
« Reply #3 on: July 05, 2010, 10:28:26 AM »
 Fuel, spark and air.
 Did you check the float bowls again to see if they had gas in them? Your floats and/or needle valves could be stuck.
 Jiggling the #4 wire is an interesting statement. Do this: Remove one of the end plugs and put it back in the wire. Hold it against the engine and crank the bike over. Do you see spark?
  Doing the outside two plugs only tells you if one coil is working, though. To check the other coil you'd have to do one of the inner plugs (2 or 3) or use a multi-meter.
 Check for fuel and spark first.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #4 on: July 05, 2010, 08:37:57 PM »
Thanks Scott S. for the help.
well, I pulled off and checked each plug...sparks on each one...  Next step I guess is to check the bowls for fuel.
« Reply #5 on: July 05, 2010, 10:07:07 PM »
It's not hard to remove the bowls and then take out the pilot and main jets for cleaning.
Does require some dexterity and patience, though.
2 1/2 years of old gas has likely gummed them up.
« Reply #6 on: July 06, 2010, 06:52:44 AM »
Thanks TwoTired... I'll flip the latches on the bowls this afternoon and work on the jets.
« Reply #7 on: July 06, 2010, 09:46:51 PM »
well the bowls were filled with fuel.. not to the rim.. about 3/4 of the way down...  gonna work on the jets now.
Re: cb750f still not running.. what's the next step..
« Reply #8 on: July 08, 2010, 03:38:04 PM »
On my way home to pull the jets out and clean everything. :-[  I just cleaned them a little, did the simple green soak and then reinstalled... I guess I missed the point of cleaning out the jets...  However, I still hadn't planned on pulling the carbs completely apart unless this is some essential reason.  I've read a few areas that you don't need to pull apart the individual carbs...  Is this bad info?
I did notice that when I dunked my carbs ( without the bowls) in the simple green bath...along with a little scrubbing... the slides got a little sticky going from closed to the full open position.  A bit of carb cleaner sprayed around and they started to slide again... not sure if that is pending doom? ???.
while i was doing the teardown, i was going to do the camchain adjustment.  I'm going to follow the FAQ's on this... Is there any other information that will help me?  Always looking for the latest tips.... ???
FAQ: "How do I adjust my camchain?
Each model engine has its best method. The 750 is the easiest. It is done without the engine running. Simply turn the crankshaft to TDCC #1, then turn it about 15 degrees farther (in the running direction). At this point, the mechanical advancer's spring retaining pin will be close to the crankcase mark. Loosen the cam chain tensioner locknut and bolt, then carefully retighten both."
« Last Edit: July 08, 2010, 03:39:39 PM by oldhondarider »
Offline Silverback
Re: CB750 still not running.. what's the next step..
« Reply #9 on: July 08, 2010, 04:56:36 PM »
Just stopped running years ago? Hmmmm, have you checked out the points? Were the new plugs wet when you pulled them again?
Chris
"It's hard to define soul. You get it in art. You get it in music, and occasionally you get it in machinery."
78 CB750F racer
78 CB750F stock
75 CB750K Baby Blue Sold (She was a great bike!)
71 CB750K (rusty rod)
77 cb550F Sold :(  Bought it Back :)
Basket case 73 CB750, 77 CB750F (Building now)
01 Aprilia Falco
76 kz400
96 BMW K1100LT
« Reply #10 on: July 09, 2010, 08:34:00 AM »
I stopped running and I didn't think a lot about why... the oil leak put it on the back burner as I was trying to rebuild my 550 at the same time..  The plugs were dry but black and sooty.
I did find something interesting...  I've never pulled the jets out of a 750 before.. not sure what these are called...I doesn't appear that they were completely clogged but it couldn't have helped.
but they had a bunch of gunk in the filters and in the cavity.
Cleaning out the jets tonight...  guitar wire...is that what i need to use on the slow jets?
« Last Edit: July 09, 2010, 08:35:32 AM by oldhondarider »
Offline CB750Ken8
  • I wanna ride...I wanna ride......Rawr MUST RIDE!
  • It's looking better everyday...jones'n to ride!!!
« Reply #11 on: July 09, 2010, 10:35:01 AM »
I believe that's your slow jet.
78' CB750 K8
Offline laser145
  • underfunded
« Reply #12 on: July 09, 2010, 10:49:15 AM »
I think the guitar wire can be handy but risky... you don't want to scar the passages or enlarge them in the slightest...
Compressed air or carb cleaner is good to use.
« Reply #13 on: July 09, 2010, 11:05:18 AM »
No, what he is holding with the screen on it is the float needle vale seat.
I agree with the guitar string warning.  Steel is hard and may gouge brass.  Yes, it can be used.  But, like many tools, some skill is required.  In this case being carful to not alter the jet orifice hole size or ramps leading to the orifice.
You carbs look clean enough that the aerosol carb cleaner can blast away or soak then blast most crud out of the jets.  The slow jet will have the smallest orifice (about 0.016" diameter).  It's the brass thing shown in the carb body with the slot across the end.
« Reply #14 on: July 09, 2010, 12:24:01 PM »
gotcha..  this thing.
I got them out... they were seated pretty good.  I sprayed carb cleaner over them...and will do the air can technique tonight.  I tried to just put the nozzle of the carb cleaner on the jet (screw side)...but nothing would come out the other end.
« Reply #15 on: July 09, 2010, 12:45:43 PM »
Soak them in the carb cleaner for a half hour or so, and give it another flow test.  When done, you should be able to see light through them.  Soak them several times, if necessary.  Blast with the nozzle both directions.
If they were hard to remove, don't put them in as tight.  They like to snap off.  I don't know what the torque spec is except just-enough-to-keep-them-vibrating-out.
« Reply #16 on: July 09, 2010, 01:15:39 PM »
Thanks TT!   :)
Re: CB750 still not running (pending).. what's the next step..
« Reply #17 on: July 12, 2010, 10:47:47 AM »
well... got everying cleaned at put back in place... blew everything out with air...everything looks pretty good.
I  had to run a few errands this weekend so I couldn't put it back on the bike....  I did have a curious question... are these markings related to a factory stamp...or is there some greater meaning?
« Reply #18 on: July 19, 2010, 07:25:26 AM »
well...crap..
got the carbs back on... and the airbox.. hooked up the gas tank......
nothing... still not starting....  I have spark... just doesn't kick over..
and now I have bowl #1 and 4 leaking... I just I didn't think I had to measure the bowl floats everytime....
sob..sob..sob
Offline ron.cieri.313
« Reply #19 on: July 19, 2010, 08:51:53 AM »
Maybe take a quick look at your main fuse...sometimes these blow due to corrosion built up over time and won't let you start it.
Making the world a better place, one motorcycle at a time.
« Reply #20 on: July 19, 2010, 09:43:52 AM »
Use a 12" 1/4" extension with a 1/4" swivel on the end. Attach a 1/4" to 3/8" adapter to the swivel and then your 18 mm socket. Stand on the right side to get to #2, left to get to #3
« Last Edit: July 19, 2010, 09:45:25 AM by MRieck »
Offline worlddrum13
« Reply #21 on: July 19, 2010, 10:12:19 AM »
^ basicaly what he said  :D
i dont know how much diffrent this is for the F, but on my k6 i figured out that u can take 12" extention and a pivot thing.(i dont know what the're called but the thing that looks life a driveshaft linkage) and the deep socket and it works great. i need to pull my tank off and there is a V in the frame that i stick the whole socket assembly down from the front and it goes right to the plugs. alternating sides on the frame will allow you to get to the other plug. a little hard to explain without lookin at it but it makes sense..trust me...  ;D
« Last Edit: July 19, 2010, 10:14:49 AM by worlddrum13 »
75 750 k6
« Reply #22 on: July 20, 2010, 09:24:38 AM »
ok... dumb question time..  where's the main fuse... I've replaced all 4 of the fuses on the fuse box....
« Reply #23 on: July 20, 2010, 09:27:57 AM »
wait... hold up... I'll go look at the manual first..    Don't want to get blasted for not checking first..lol
Offline KB02
« Reply #24 on: July 22, 2010, 04:50:07 AM »
 ;D ;D ;D ;D ;D ;D ;D
Should be one of the four in the box.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
