Author Topic: Roach 78 cb550 build "its never really done is it?" New PICTURES UP  (Read 14786 times)
Offline Roach
so my noobie question
i have found a realy nice 78 cb 550k and im not sure to get it or not. i am 6'1 i want to cafe it and my question is will i be able to fit on it and have rear sets?
or should i try and trck down a 750
i have realy fallen for the 550 style but not sure with my hight it will work
thanks roach
« Last Edit: April 14, 2012, 09:50:54 PM by Roach »
1978 CB550K Cafe Racer
Offline fastbroshi
  • Puppet
Re: cb 550 or cb 750
« Reply #1 on: July 08, 2010, 11:35:26 PM »
  The 750 has more power and the probably made more of them, but it's heavier and doesn't handle as well as the 550 right outta the box.  The motor also has to come out of the frame for any top end work on the 750.  On the 550 you can do it with the motor still mounted.   And top end problems do rear their heads, usually an o-ring at the ends of the head or chain tensioner that won't work.
  There also seems to be a lot more changes throughout the 750 model years that make parts non-interchangeable,  mostly cosmetic stuff.  A 750 expert can chime in here.  The 550s seem to interchange pretty well from F and K with a few exceptions.
   If you like the 550 enough to consider getting it, I'd check the operation of the cam chain tensioner, pull the tank and sidecovers and do an inspection of the wiring harness to see if it's hacked up or burned at all.  Those seem to be the biggies on the 550s.
   I'm 5'11" 190 and I fit on the 550 okay, though it was uncomfortable at first because of my clubman bars.  I work out a lot more now and it's fine.  Shoulder and forearm strength is key here.  My brother says I look huge on it.  Truthfully I think some true clipons would be best.  They're a little higher and usually not as sever an angle as the clubmans.  Lots of people do rearsets, just do a search.
« Last Edit: July 11, 2010, 12:26:16 PM by fastbroshi »
Just call me Timmaaaaay!!!
Offline Roach
« Reply #2 on: July 10, 2010, 10:26:42 PM »
well i picked up the 550 today came with almost every replacement part i can think of. only problem is the motor is in a million parts.
Offline Shoeboxjoe
  • Large Breasts
« Reply #3 on: July 10, 2010, 10:51:44 PM »
Congrats! Post some pics when you get a chance.
joe
1977 Honda CB750K Project IDK yet
http://forums.sohc4.net/index.php?topic=121669.0
SOLD 1976 Honda CB750K Cafe project
http://forums.sohc4.net/index.php?topic=52576.0
1964 Honda Trail 55 (C105T) Custom project
http://forums.sohc4.net/index.php?topic=64962.0
1967 Norton P11 (restoring for father-in-law)
1978 Ford Fiesta (at body shop!)
traveler
« Reply #4 on: July 10, 2010, 10:53:20 PM »
I'm 6'2, 218 Lbs, and I built a 550....
Welcome, and good score!
Need any help or ideas just give a shout!
~Joe
Offline Roach
Re: Roach 78 cb550 build
« Reply #5 on: July 15, 2010, 11:22:11 PM »
I am taking lots of pictures as I go so stay tuned
Offline Roach
« Reply #6 on: July 16, 2010, 10:35:02 PM »
so here are pics from when i just got the bike home.
« Last Edit: July 16, 2010, 11:59:23 PM by Roach »
Offline Roach
« Reply #7 on: July 16, 2010, 10:50:52 PM »
cleaning stuff up
Offline Roach
« Reply #8 on: July 16, 2010, 10:54:07 PM »
so i put on my new dyna coils but now i need new wires... what should i get?
Offline MasterChief750
  • Detonation
« Reply #9 on: July 17, 2010, 03:25:02 AM »
why not dyna wires. z1 carries them at a good price too.
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
traveler
« Reply #10 on: July 17, 2010, 08:48:33 AM »
Looks great!
~Joe
« Reply #11 on: July 17, 2010, 02:14:39 PM »
Nice! Do you have the black parts powder coated or they came like that?
Offline Roach
« Reply #12 on: July 17, 2010, 02:45:58 PM »
I got them bead blasted then primed them and used like 3 coats of caliper paint sanding between coats turned out amazing.
Offline Roach
« Reply #13 on: July 19, 2010, 05:48:25 PM »
Ran into a big snag on the weekend...got all my gears and crank back into the case but.........and i mean but....the guy i baught the bike off of snaped the bolt that holds the two cases together. I tried to tap it out myself but that didnt work looks like its going to the shop tommorow. >:(
Offline Roach
« Reply #14 on: July 20, 2010, 07:11:20 PM »
anyone know of any smaller indicator lights that attach to the forks in the stock location been looking and looking and cant find much.
Offline Roach
« Reply #15 on: August 24, 2010, 07:27:11 PM »
so after a month and a half wait for my cases.....I finaly got them back. Motor is all back together and in the bike. Started up first kick no leaks nothing. so Im a happy puppy. sounds great.
next is paint ,seat, fairing, rearsets
« Reply #16 on: August 24, 2010, 07:30:35 PM »
Great news! What color paint?
Offline Roach
« Reply #17 on: August 24, 2010, 09:25:20 PM »
im thinking a dark red or go back to black
« Reply #18 on: August 24, 2010, 09:38:46 PM »
Aren't the green Dyna coils 3 ohm?
If so, they suck two much power for the 550's charging system.  You can expect dead batteries, (and dead bike) frequently.
Trade them for 5 Ω primaries.
Offline Roach
« Reply #19 on: August 29, 2010, 11:09:58 PM »
havent ran into any problems as of yet with the coils. but time will tell I'm guessing it could be do too the new battery
Offline Roach
« Reply #20 on: September 03, 2010, 12:40:03 PM »
so you were right about the coils they drain my battery alot.... question is what can I do about it other than changing them out. they abviously can work some how..cant they?
other question got new mini indicator markers. got them to blink for a bit then they went dead.checked my flasher its fine. the wiring diagram says that theres a (black,gray and green wire) the black and gray are hooked up to the flasher where does the green wire go? dont see anywhere for it to plug into.
thanks for the help
Ps keep posted new pics and video of it running will be up soon
« Reply #21 on: September 03, 2010, 03:29:26 PM »
You can reduce the coil power draw some by inserting a 1 ohm resistor in series with the coil power input.  But, it still won't be as low as 5 ohm coils.  I didn't notice if you are using points or a dyna ignition.  The dyna-s will make all coils draw ~30-40% more power than the points do, as they provide far less "off time" to the coils than points do.
Some flashers are three terminals types.  The green wire is a ground for those to use.  Honda says, "you're welcome".
Some flashers are load and voltage sensitive.  As the battery drains away from peak charge, they slow or stop flashing.
The stock flasher was selected to match the stock lamp loads.  Want to be an engineer?  Deal with design changes.  ;D
Offline Roach
« Reply #22 on: September 03, 2010, 03:39:27 PM »
im running the dyna ignition cant stand dealing with points.. thanks for the help TwoTired
Offline Roach
« Reply #23 on: September 03, 2010, 05:42:38 PM »
so i yanked out the dyna coils and went back to stock. too bad too i like the red dyna wires. but still cant figure out my flasher
if i take off the black wire and attach the green wire it flashes but gets hot fast... maybe i need a 3 pronged flasher?
Offline Raef
« Reply #24 on: September 03, 2010, 05:48:16 PM »
Do you have a solid state flasher, if not you can get them at the autoparts store they take very little current to trip and will work with LED's or standard bulbs
Mark
and you can get them in 2 or 3 prong
