Author Topic: Re: Hey 750f1 guys UPDATED  (Read 824 times)
Offline xfactor
« on: July 30, 2010, 06:31:20 PM »
Have you ever replaced the rear brake caliper? I was reading it today and it says to remove the wheel, could I just slide the axle part way though and pull off the caliper instead? It seems like it would be possible to only remove the axle part way.
Croix
« Last Edit: July 31, 2010, 05:06:35 PM by xfactor »
Offline david 750f
  • 1976 CB750F
Re: Hey 750f1 guys
« Reply #1 on: July 30, 2010, 07:17:39 PM »
It should work. My guess is that you don't have a centre (center) stand ;) ;) ;)
1976 CB 750F
Re: Hey 750f1 guys
« Reply #2 on: July 30, 2010, 08:37:03 PM »
Snug but doable.
Offline xfactor
« Reply #3 on: July 31, 2010, 05:06:24 PM »
AND ITS DONE, with some force of course.
Another question for you pros, the linkage that is on a spring that pull the pedal has a plastic nut, well mines broken, meaning I literally have to stand on the pedal for it really stop the back wheel. DO you fellows know any fixes for this, or where I can pick a new one up??
Croix
« Reply #4 on: July 31, 2010, 07:24:38 PM »
The only plastic nut I can think of is on the brake light switch which has a spring that attaches to the SKU: 46510-392-000 SPINDLE, RR. BRAKE PEDAL on the other end??!! That has nothing to do with stopping. The brake light switch is readily available SKU: 35350-KJ9-405 SWITCH ASSY., RR. STOP (Honda Code 3780665) 1 $9.91 . The other spring I think of is actually for the pedal to keep it recoiled back (no braking position). Can you look up a parts diagram and give the Honda part number you are referring to so we can look it up to be sure what you are referring to?
Offline xfactor
« Reply #5 on: July 31, 2010, 07:39:39 PM »
Actually you are spot on. But my brakes are still very very squishy, but they at least work so I cant complain too much.
