Author Topic: brake line #2  (Read 1610 times)
eldar
brake line #2
« on: February 24, 2006, 03:29:42 PM »
OK I answered my own question I had before but now I have a new one. I stil want to replace my line. Now My brake line is like the rest of the K models. It has the line connected to a steel tube that goes to the caliper.
How would I connect the new line to that tube, or can I remove that completely and use a short banjo bolt?
I would like to get rid of the tube and just have the line go from the master to the caliper.
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
Re: brake line #2
« Reply #1 on: February 24, 2006, 03:54:18 PM »
Why can't you just replace the entire line, from master to caliperĀ  ?
Go to any V-Twin shop , and they will have all the Goodridge brake parts you could need
to make up your own brake line, fittings and all...
My stock caliper has that stupid hard line on there as well.
I plan to replace with all stainless once my dual-disc setup goes on the bike..
« Last Edit: February 24, 2006, 03:56:18 PM by ProTeal55 »
eldar
Re: brake line #2
« Reply #2 on: February 24, 2006, 04:02:04 PM »
Well I am actually working with helusa right now to do it and it wil only cost me $50 for everything. Could not even do it myself for that price.
I mainly need to know what will fit in that hole.
Online bryanj
Re: brake line #2
« Reply #3 on: February 25, 2006, 02:53:14 AM »
You can either use a shortened banjo bolt with a banjo fitting or there is an adaptor from M10 to the goodrich thread and then a "swivel elbow" that goes on the end of the pipe. I have both and make my own lines up. If you email me with your address i can send you a document with some pictures in
Offline KB02
Re: brake line #2
« Reply #4 on: February 25, 2006, 05:10:52 AM »
The only problem that you'll have ay the V-Twin shop is when it comes to getting a connection that will fit into the caliper. They'll look at you funny or laugh when you mention either "honda" or "Metric." At least that was my expeirience.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
eldar
Re: brake line #2
« Reply #5 on: February 25, 2006, 10:33:02 AM »
Thats couse most of the mechanics in Vtwin shops are not good enough to work on a honda! ;D
Offline KB02
Re: brake line #2
« Reply #6 on: February 25, 2006, 01:19:21 PM »
 ;D ;D ;D ;D ;D ;D ;D ;D
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline nomadwarmachine
  • 1972 CB750K2, 1974 Norton Commando 850 Mk2
    • Nomadwarmachine.com
Re: brake line #2
« Reply #7 on: February 25, 2006, 02:58:01 PM »
Just send HEL USA your old brake lines and they will turn around a new set in a couple of days or so.  I went through them and they matched all of the fittings/length perfectly.  Check the results here:
http://www.nomadwarmachine.com/gallery/view_photo.php?set_albumName=album35&id=IMG_0037
http://www.nomadwarmachine.com/gallery/view_photo.php?set_albumName=album35&id=IMG_0039
Offline Egil
SV: brake line #2
« Reply #8 on: February 26, 2006, 09:00:13 AM »
If you go direct from  the frontbrake cylinder and down to the caliper white new brake lines  !
Hope you don`t forget the the front brake light switch that sits`s under the front light on some models 8)
73 de La2vpa.
Egil.
On The Edge.....That`s Where We Live Every Day.
My bike :
http://bike.no/member/photo.php?id=1605
Offline ProTeal55
  • Est1968.com
Re: brake line #2
« Reply #9 on: February 26, 2006, 11:09:14 AM »
Good point ! I plan on running a new-style master with that nifty little switch to get rid of the stock unit.
eldar
Re: brake line #2
« Reply #10 on: February 27, 2006, 08:00:06 AM »
My master has the light button mounted to it. So I use a straight line from the master to caliper.
Offline Egil
SV: Re: brake line #2
« Reply #11 on: February 27, 2006, 11:15:06 AM »
"master Eldar "  have you a ligth button mounted on on you  ???
73 de La2vpa.
Egil.
My bike :
