I bought a $400 1972 CB750 a couple months ago and am just now getting around to trying to get it ready to ride. The bike had been sitting for 15 years before I got it.
I already replaced the exhaust, although the eBay auction lied and it's definitely not for a CB750K, although the headers fit, the muffler is certainly not correct, as the bracket on it is nowhere near attaching to anything on my bike. Maybe it's for an F model? For now it will provide backpressure and allow me to get the bike running/semi-tuned.
I took the float bowls off and there was nothing in them. I removed and cleaned the jets, although they were mostly fine. The PO must have ran the carbs dry before storing the bike, they really were pretty clean inside. The gas tank was also very nearly empty and clean. A little swish of some new gas and draining and it's clean and good to go.
I've also cleaned and adjusted the points, checked the valves, changed the oil/filter, checked compression (100/100/100/95 or so) with a automotive tester, and replaced the battery.
I've put about 2 gallons of gas in the bike and managed to get it to fire up. It was missing on a couple cylinders and running pretty poorly, but it would idle. This was with open headers before I bought my "new" eBay set. I've since clipped the ends off of the spark plug wires and reinstalled the caps, cleaned and gapped the plugs, and installed this new-to-me exhaust. It still runs very poorly, and still is running on only two cylinders, except now it's two different ones than before!
I've decided the best thing to do is probably to clean all the wire connections and make sure the coils are getting the electricity they need. What would you guys suggest I do first? I don't want to put money into rebuilding seized brakes and replacing all of the cables until I know it will run correctly. That's got to be my priority right now I think.
Anyone in or near Tacoma, WA that wants some good beer can feel free to come help me!
