Author Topic: the wires in headlight bucket  (Read 1485 times)
Offline MikeJW
« on: August 28, 2010, 07:41:10 AM »
Hey all,
well, every time my turn signals stop working (once or twice a month) I get out the screwdriver & take off the headlight. One (or more) wires have vibrated out of their bullet connectors; laying loose inside the shell. Getting a bit tired of this recurring prob. Is there any logical objection to cutting out the connectors and soldering the wires together and maybe putting wire nuts on the soldered joints?? ??? I've tried taping everything in place but the bikes is 39 years old...1972 750K2
Thanks, Mike
1972 CB750K2
Offline curtis
Re: the wires in headlight bucket
« Reply #1 on: August 28, 2010, 08:35:35 AM »
I have soldered wires in the headlight bucket myself and worked just fine onley thing is if you need to change handle  bars or blinkers you have to start cuttin and resolderin but another option is you can still get new conecions still allot of work. What ever you do will work fine the conectors I did reuse I pinched with a pair of pliers and they are holding fine.so far
« Reply #2 on: August 28, 2010, 08:47:30 AM »
You can also get single connectors or entire kits for these bikes, with improved-quality connectors, from www.vintageconnections.com. The owner, Del, is a GREAT guy and will be a big help to you. He sells even a hand crimper of excellent quality for about $30 that is perfect for all the connectors on the bike: don't know how he can afford that. I build all my electrical products with his stuff, first rate, low cost.  :)
Offline Tintop
« Reply #3 on: August 28, 2010, 09:09:27 AM »
+1 Hondaman on Del at Vintage Connections.  Using his connector kits for my build.  Quality stuff.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline MikeJW
« Reply #4 on: August 28, 2010, 09:16:52 AM »
Thanks, guys, I checked out the website and it looks like he has everything you would need. I guess I'd rather do that than solder.
Mike
1972 CB750K2
Offline Johnie
« Reply #5 on: August 28, 2010, 09:17:55 AM »
I bought a nice box of OEM connectors from yamiya before I knew about the USA site. Some in my bucket were lose and I just used a pliers to crimp them a bit and they held better.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline swellguy
  • An electric cattle prod is a
  • Divorce is so expensive because it's worth it.
    • http://ksphotos.com
« Reply #6 on: August 28, 2010, 09:37:33 AM »
I purchased one of his kits and they are the cat's ass.
This project started in confusion and will end in disarray.
http://forums.sohc4.net/index.php?topic=76471.msg852227#msg852227
