Author Topic: Headlight shell grommet  (Read 1297 times)
Offline 765fitty
« on: September 25, 2010, 11:00:49 AM »
Was wondering, my '76 550's head light shell has no rubber grommet where the wiring comes in.
Is there supposed to be one?  Seems like there should.
If it's missing, where can one find one?
Thanks!
Freddie
Save your $. Adopt an old Honda and give it a nice home.
Offline joealex
Re: Headlight shell grommet
« Reply #1 on: September 25, 2010, 11:11:31 AM »
Mine didnt have it either but sice you mention it,you are rigth it should have some,just a thought you can try with that car door protectors that you put on the corner of the doors they go like $1 it might work fine,just my 2c.Joe-
Offline 765fitty
« Reply #2 on: September 26, 2010, 04:59:21 AM »
Yeah that's a good idea.  Wonder if it's just us two, or there never was one.
Thanks for your suggestion.
Freddie
bollingball
« Reply #3 on: September 26, 2010, 05:21:26 AM »
You can buy rubber grommets at most auto parts store they also have kits with several sizes in a plastic tray.
bollingball
« Reply #4 on: September 26, 2010, 05:41:08 AM »
My 750K8 does not have one and I don't see one in the parts manual all my wires are covered with a sheath at the hole in the bucket I think it would be difficult to put one in you could use a piece of tubing split longways cut to length and glue it.
Offline Blueridgerunner
  • CB650 no longer, but do have an 87 GL1200
« Reply #5 on: September 26, 2010, 05:47:33 AM »
None on mine either. I figure that the heat generated in the light bucket is partially vented through the opening.
Said James "In my opinion,  there's nothing in this world, beats a '52 Vincent and a red headed girl"
Laissez les bons temps rouler
Offline drones76
« Reply #6 on: September 26, 2010, 07:47:07 AM »
A piece of rubber window insulation will work also.  Cut to fit and glue.
1974 Norton Commando Roadster
1980 Goldwing Interstate
1975 Kawasaki KZ400D
Looking for a SOHC-4
Offline ksmith0034
  • When I grow up I want to be a
    • Please subscribe to my motovlog
« Reply #7 on: September 26, 2010, 08:47:12 AM »
Neither of my buckets (original and new) have one on my CB750.  Since I need to paint my new bucket anyway, I think I will sand the corners over a bit instead of adding a grommet.
It took 10 years but she's finally done!
Stocker 2 Rocker CAFE conversion
My YouTube channel HERE:
https://www.youtube.com/MotoCafeRacer
