Author Topic: Empty ground battery cover cb750k6  (Read 733 times)
Offline highrpms
« on: September 27, 2010, 08:13:36 PM »
There is a female solid green wire by the turn signal relay. It's right from the red w white recitfier wire and the power wire and the two wires going to the turn signal flashed relay. I know that solid green should be a switched ground but I don't see any place it should attach to in that area unless that flasher relay should have 3 wires instead just the two on there.
Thanks.
1976 cb750k6
Re: Empty ground battery cover cb750k6
« Reply #1 on: September 28, 2010, 06:06:19 AM »
That is the phantom green wire. It goes nowhere. They use the same harness on several bikes. Drives everyone nuts at first.
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: September 28, 2010, 06:10:56 AM »
When you open up the headlight bucket you'll probably find an unused brown wire, too.
