Author Topic: my plan to un-freeze a 1974 cb750 motor  (Read 24802 times)
Online Stev-o
Re: my plan to un-freeze a 1974 cb750 motor
« Reply #50 on: December 14, 2010, 06:17:04 PM »
Thanks for all the info on here on this, as I picked up a K5 week before last with a seized motor.  Tried the acetone/ATF trick, and damn!  6 days is all it took on a bike with 7 years outside and an 836 kit.  Mostly stock other than that.
Two cylinders at 140-150, and two at 65psi.  Soaking them again to see where it gets me...
That compression may come up on the two low ones after you run it.
Offline MoMo
  • Ride like you're invisible
« Reply #51 on: December 14, 2010, 07:10:58 PM »
That's great ;D.  If you are able to get it started the compression will come up on the other two.  Further dousing should help.  I usually use Seafoam to unseize motors but that cocktail seems to work better to free up after years of sitting.  Every bike that I have managed to get unstuck was not taken apart and are still running...Larry
Offline dirtmagnit
« Reply #52 on: December 14, 2010, 09:09:43 PM »
Tried the Seafoam last night, but nothing in the bores when turned over today.  That seafoam is pretty thin.  Put A/a back into it today for a day or two.
I must say, being the first 750 I've played with, I love the springs on the float bowls.  After 3 550's, 2 400F's, a 350F, and a couple GL1000's, I love popping them off to check things out with the rack still installed.  Carb's are plugged solid, but a cool feature nonetheless. It'll run on ether (just to check) so I guess I know what needs to be done.  Not looking forward to the carbs...
e
I'd rather burn rubber than clutch...
Another Honda sucker. Currently..  76 CB550F Project, 75 CB750k, and rides a GL1000 daily.
Past:CB400f(75');CB350F(73'?);CB550K(74');CB550F(76');CB400F(75');GL1000(77') and others(I'm tired..)
Offline faux fiddy
  • bike in a box
« Reply #53 on: December 19, 2010, 11:59:13 PM »
50/50 ratio of ATF and acetone is the ultimate unsticker. Try and see if you can rotate the bolt on the points side first, don't hammer on it too much though. If it doesn't budge on that side pour in the 50/50 mixture and let it work it's magic for a day or two then repeat.
+1 on the ATF, never heard of mixing it with acetone, but that should cut some grime.
Heat never hurts, but seems impractical in your situation. I agree with the stuck rings, etc. You'll probably want to pull  the bores off eventually.
I  used a piece of delron (a machinable dense plastic) and a hammer for beating on the tops of the pistons to loosen them in the bores.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline terecha
« Reply #54 on: June 02, 2013, 03:24:21 AM »
hi
I have small question. I have a problem with stuck piston. I didn't remove the valve cover and I did turn the kickstarter shaft using long wrench, the kickstarter shaft turned very hardly. I did 2 full clockwise turns. Later (after I removed the cover) I noticed the piston is completely 'welded' to the cylinder (no chance to move and didn't move when I turned the kickstarter). So when I moved the kickstarter shaft, could I cause serious damage inside? The bike was on neutral then.
Offline goldarrow
  • one day, i'll be an
« Reply #55 on: July 24, 2014, 10:55:37 AM »
I will try that method. Why don't you think it will work for me?
SO, did it work for you?  just freed up my K2 motor and kick starter won't move.
« Last Edit: July 24, 2014, 11:00:33 AM by goldarrow »
CB550 K0
Online Stev-o
« Reply #56 on: July 24, 2014, 08:48:48 PM »
I don't remember trying kicking the kickstarter to the rear.  Shorty after that, I bought my K4 and put the K7 on the back burner in the Batcave where it's been ever since.  I wouldn't doubt it's stuck again.
I'm working on the title process (have VT reg) and plan to pull it out this fall.
Kick it to the rear!
Offline goldarrow
« Reply #57 on: July 24, 2014, 08:59:10 PM »
Couldn't wait for your reply, so I went ahead, and hammer it it rubber mallet.  It came loose. Now I'll just have to open the head and see the bores as I hAve a feeling the rings scrapes the walls as I turn it.
CB550 K0
Online Stev-o
« Reply #58 on: July 24, 2014, 09:28:39 PM »
Good to hear you got it free.  Don't want to try to fire it up? I would...
Offline goldarrow
« Reply #59 on: July 24, 2014, 09:30:21 PM »
The motor doesn't turn smoothly, and feel like something rubbing,binding in there...
CB550 K0
Online Stev-o
« Reply #60 on: July 24, 2014, 09:33:57 PM »
Not good, ya, it has issues.  Well at least your a Pro at pulling those motors quickly!
Offline goldarrow
« Reply #61 on: July 24, 2014, 09:35:10 PM »
Lol. Will see if I have time to do it this weekend.  And the title for this bike just came in :)
CB550 K0
Offline Oldtech
  • Motorcycle tech: old, cranky and retired
« Reply #62 on: July 25, 2014, 05:57:22 AM »
When I've tried everything and the motor is still stuck so that I'm sure it will have to come apart I use a much more gentle method to free the pistons then beating them with a block of wood and a hammer. Pull the tappet covers and see if one of the cylinders has both valves closed. If not the cylinder head cover has to be removed. I have a collection of spark plugs with the centers knocked out and threaded to take a grease fitting (grease zerk). Thread in the modded spark plug and put a grease gun on it. A grease gun can generate really high pressure so keep pumping until the cylinder fills and the grease starts putting pressure on the piston. This hasn't failed me yet and I've managed to get several engines apart that only needed a light hone and new rings afterwards.
« Reply #63 on: July 25, 2014, 07:20:24 AM »
That's a great idea. IF it works as well on pistons as it does on brake calipers, it would be fantastic. I looked it up and a simple pump handle grease gun generates 5000+PSI in short, safe bursts. It would sure be a more elegant way of popping a piston than some of the medieval methods described here.
