Author Topic: which tool do you use for the front wheel retainer?  (Read 1762 times)
Offline mazingerzeca
« on: October 04, 2010, 11:32:37 AM »
Hello all.
Is there any specific tool for the front wheel retainer? I'm referring to this:
Offline CycleRanger
  • No comment about being an
Offline cobra2411
Re: which tool do you use for the front wheel retainer?
« Reply #2 on: October 04, 2010, 12:14:33 PM »
Hammer & screwdriver... The flat one, not the pointy one that looks like a cross...  :D
Hey that's what all the POs did...  ::)
Gotta get me one of those tools...
« Reply #3 on: October 04, 2010, 12:34:55 PM »
But you must remember to drill out the stakes first or the tool will be of little use.
BTW- many of us have made bearing retainer tools.  A flat strap of steel 1" wide, 24" long +/-. Near the center drill 2 holes spaced to match 2 retainer notches. Put a small, short bolt in each hole, secured by a nut with a few threads of the bolts sticking out.. Mesh the 2 bolts into the retainer, turn the strap piece of cake.
« Reply #4 on: October 04, 2010, 02:15:14 PM »
I would suggest you do a search and you will find a lot of homemade tools and tips. Many with pictures. Don;t use a screwdriver.
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
« Reply #5 on: October 05, 2010, 09:30:11 AM »
Yes be sure to drill the 4 staked punch marks, just deep enough to remove them.
I used this, just a piece of steel filed to shape and shoved onto a handle.
http://i192.photobucket.com/albums/z293/galaxy8155/DSC02451.jpg[/img]]
Offline Gamma
« Reply #6 on: October 05, 2010, 09:38:15 AM »
Because the hub is not laced yet I put it in the oven to make the bearings easier to remove.
I tightened it up with the same tool, and it has gone past the original position a little, then re-stake the retainer with a punch.
http://i192.photobucket.com/albums/z293/galaxy8155/DSC02509.jpg[/img]]
Offline Flying J
« Reply #7 on: October 05, 2010, 10:00:43 AM »
Is it really necessary to restake them? How is that going to come undone?
« Reply #8 on: October 05, 2010, 10:04:14 AM »
If it goes in smoothly, and you don't crank it into place, heat cycles could loosen it. I don't think it should be cranked down hard, just snug, so a couple taps with a centerpunch can't hurt.
Offline Gamma
« Reply #9 on: October 06, 2010, 09:25:46 AM »
Agree with you MCRider
