Author Topic: $200 Score From Craigslist!  (Read 4635 times)
Offline SOHC Digger
  • I'm not an
Re: $200 Score From Craigslist!
« Reply #25 on: November 23, 2010, 08:16:00 AM »
Spent some more time on it last night and this morning.  I put a new seal in behind the points, but that wasn't the leak.  Whoever was in there last forgot to put the little o-ring behind the advance and that's where the oil was coming from.  Oh well, easy fix.  I must say, whether it was the PO who did work in this area or the mechanic he took it to, they knew just enough to be dangerous.  Instead of fixing the oil leak, they siliconed the points cover and bolt holes in an attempt to keep the oil in.  I've heard of wet clutches, but never wet points!
Bike still wouldn't idle, even though it's in the 40's here, so I pulled the carbs off and threw on a freshly rebuilt set I have for my other project.  Bike fired right up and idled smoothly.  PO says the carbs were just rebuilt... in 2003.  I guess I will be going through those too.  At least that can be done inside where it's warm.  Maybe I'll make a nice step-by-step PD carb rebuild thread with lots of pics!
Last thing I have noticed with this bike is that the starting gear sounds like it's missing some teeth.  I haven't taken the alternator cover off yet, but I'm hoping it's just the starter gear and not the crank gear.
« Reply #26 on: November 23, 2010, 06:20:55 PM »
Famous last words: "they were just rebuilt!"
Offline SOHC Digger
  • I'm not an
« Reply #27 on: November 23, 2010, 07:06:26 PM »
Yeah, Stev-O, that kind of stuff is all too common.  There are some people who believe in disclosing everything about something they are selling because they would want the same in return and there are some people who believe the better they make something sound, the more money in their pocket.  I am of the first group because I believe in karma.
« Reply #28 on: November 23, 2010, 07:22:19 PM »
Another classic seller's line is "it ran great when I parked it!" [10 years ago!!]
Offline SOHC Digger
  • I'm not an
« Reply #29 on: November 23, 2010, 07:29:54 PM »
I'm starting a new thread:  Seller's famous last words!  In fact, I'm going to right now.
Offline SOHC Digger
  • I'm not an
« Reply #30 on: December 09, 2010, 04:58:48 PM »
So, I pulled the alternator cover off and inspected the gears.  The crank gear, idler gear, and starter gear seem fine.  Maybe this is a starter problem.  I just got the gasket to put the alternator cover back on so I will clean it and button it back up.  I have another starter, so I will throw that in and see if it alleviates the problem.
Offline SOHC Digger
  • I'm not an
« Reply #31 on: March 03, 2011, 06:09:42 PM »
And she's up for sale!
Here's the link to the sales thread:
http://forums.sohc4.net/index.php?topic=84786.0
