Author Topic: Holy crap! It runs!  (Read 962 times)
Offline johnrdupree
Holy crap! It runs!
« on: November 13, 2010, 04:09:43 PM »
My new-to-me 1975 Cb550 came to life tonight, after sitting in a shed for a year (at least that's what the seller told me).  I didn't even do any actual work on it.
Right after I got it, I put in a new battery and ground cable.  The old cable had gone missing so I bought a generic ground cable for a lawn tractor at Tractor Supply.  Don't laugh, it works.  The start button is missing (maybe it's hanging out with the ground cable) so I used the eraser end of a pencil to spin it over.  It spun fine, the oil light went out, and it sounded like it wanted to run, but that nasty old gas wasn't going to cut it.
Today I removed the tank and drained it, along with the carbs.  Pulled the plugs, cleaned them, and checked the gaps.  I checked for spark on #2 and #4 (present), put the tank back on and filled it with fresh gas.  I jammed the pencil in the starter button hole and after a few spins it started right up.  That was a pleasant surprise.  I revved it a couple of times and it blew chunks of exhaust innards out the back.  I couldn't resist and, against my better judgment, I took it around the block a couple of times.  It did mostly OK.
Now the real work begins.  My mental to-do list so far:
Oil and filter
Check for air leaks (the #4 airbox boot has holes)
Adjust valves
Check timing
Sync carbs
Tires (the front feels like it's made from granite) and tubes
Brake pads
Bleed and adjust brakes
Fork seals (the left is leaking)
Chain and sprockets
And a hundred other things I can't think of right now.  But hey, it runs.
[youtube=425,350]EZEY6IV_p3c[/youtube]
~john
« Last Edit: November 13, 2010, 04:18:19 PM by johnrdupree »
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
1954 NSU Lambretta 125 (long term project)
Re: Holy crap! It runs!
« Reply #1 on: November 13, 2010, 04:18:14 PM »
Good feeling isn't it?!!
I resently bought Bridgestone tires for my 550 from:
[on sale w/free shipping]
http://www.motorcycle-superstore.com/1/28/396/6020/ITEM/Bridgestone-S11-Spitfire-Sport-Touring-Blackwall-Front-Tire.aspx
Offline Alan F.
« Reply #2 on: November 14, 2010, 08:51:52 AM »
Very cool!
+1 on motorcycle superstore for tires, I've never seen better deals anywhere and I've gotten free shipping even when they weren't advertising it.
Alan
Offline johnrdupree
« Reply #3 on: November 15, 2010, 06:35:57 AM »
It does feel good, especially since I was expecting it to be a lot more trouble.  I had an '81 CB750K that fought me tooth and nail.  I must have had the carbs off that thing a dozen times just to get it to run reliably, let alone correctly.  It looks like the 550 is just going to need a basic tune up to run right.  Famous last words, you know?
Thanks for the tire links.  I hadn't started to investigate that, partly because I thought I'd spend more time just getting it to run and partly because I'm going after a certain aesthetic (wrenchmonkees) that dictates the tire choice.  I can't decide if I should bite that bullet now and get do the rims and tires the way I want them, or install a set of stock sizes while I work through some of the maintenance issues.  Since money is always an issue, I'd hate to buy tires that may not be on the bike very long.  I'm sure it will work out eventually.
~john
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
