Okay I got the jets in. Thank you again Jim for the help. However on closer inspection with both sets of jets to compare/contrast, my jets didn't seem to be drilled out after all..
I went through everything again. Checked all tappets. Checked point gap and timing. Checked that the floats were all set at 22mm. Petcock was clear of debris. Bench synced again. Checked for debris in gas, and in bowls.
Everything is running as it should. Running on all four cylinders. With all the richness and condensation I decided to take it out and put a few miles on it to see if it would burn some of that crap off..
Came back and saw that #3 was pouring out gas from the overflow tube.. Stuck float valve. Put it back in the garage and took down the bowl from #3 and #4 and swapped the float valve. Checked the spark plug from #3 and #4 since I was on that side. The plugs weren't wet but they were blacker that a moonless night.
Put everything back together. Fired it back up. There was less to no more condensation (white smoke) from exhaust and breather tube, but black smoke still coming out and burning my eyeballs, so I took it back out again. On this trip the engine never opened up and acted like it was running out of gas. I know on my 750 that when this condition happens I know I am running out of gas and it is time to switch it on reserve, and when I do the problem remedies itself and I know its time to get to a gas station.
However there is still over 1/2 a tank of gas in the tank. The bowls are full, and yep you guessed it the spark plugs are blacker than owl sh*t. The AMS are all set to 2 full turns out. There are no kinks in the gas lines. and the bowls were still full, all levels about the same from one bowl to the next.
The problem I am facing is I will go back to an airbox (As soon as I can get some boots for them, and I am going to put 4-2 exhaust with mufflers on it. Both of those things reduce air flow and will therefore increase richness. If it is already running as rich as it is, what the heck am I going to do when I add those parts and increase the richness??!!!
I have another, unused set of spark plugs that I haven't put in there yet, This would be the 3rd set I have purchased, and dont want to ruin them and foul them out just yet if it is running on all 4's.
I can't really decrease the fuel levels in the bowls more that what they are, (Which I have tried in the past) because then there will be no gas in the bowls and it definitely wont fire then.
How do I reduce the richness of the bike?
The jets are factory size
The floats are set to factory setting
The tappets are set to factory setting
Point Gaps are set to .012, and timing is set
bench synced with 1/16th bit
Only thing that isnt factory from my knowledge is the exhaust and airbox at this point.
Any chance the cam shaft has been changed to 650? I don't think it would make a difference in gas mixture at all, but if it is how do I figure that out?
I'm ready to sell it and cut my losses.
