Author Topic: Can somebody explain this? Drilling a rotor increases it's surface area.  (Read 6685 times)
Offline fastbroshi
  • Puppet
I assume they meant pad swept area?  If that is what they meant, then how?  From the webpage:  http://www.vintagebrake.com/tips.htm
Sixth heading under Disk Brake Tips
Disc lightening--drilling vs. thinning: both will reduce mass and therefore heat sink capability. Some pluses for drilling.: If the holes drilled are smaller in diameter than the thickness of the disc, surface area is increased.
Just call me Timmaaaaay!!!
Offline Hopper
Re: Can somebody explain this? Drilling a rotor increases it's surface area.
« Reply #1 on: December 27, 2010, 02:31:27 AM »
I think what they mean is that the total surface area of the disc is increased, therefore increasing the cooling area, but not increasing the swept area.
The surface area of the cylinder that is the inside surface of the hole is greater than the former two small circles of flat space that were sacrificed by drilling the hole.
Offline fastbroshi
  • Puppet
« Reply #2 on: December 27, 2010, 02:43:05 AM »
Okay, but do you have the formula to figure that out, jk :)
Markcb750
« Reply #3 on: December 27, 2010, 03:02:41 AM »
(Pi x D) x L x N
Pi =3.14159....
D=drill dia
L= thickness of rotor
N= number of holes
Opps, what can say I'm old.
« Last Edit: December 28, 2010, 03:54:48 AM by Markcb750 »
Offline fastbroshi
  • Puppet
« Reply #4 on: December 27, 2010, 03:24:20 AM »
Nice, thanks Mark.
Offline turboguzzi
« Reply #5 on: December 27, 2010, 03:37:24 AM »
its also well explained in john robinson's book "motorcycle tuning - chassis"
the crazy drilling fad (more holes than disc... :) ) was really massive when discs where thick and heavy due to novelty/playing it safe.
if the tracks your race on have long straights with heavy braking at the end, you would want to maintain some heat sink capacity and not reduce weight at all costs,
Personally, i run gs750 discs thinned to  4.5 with not much drilling, got holes there for good pad cleaning and wet braking rather than reducing weight,
TG
Offline mlinder
  • "Kitten Puncher"
  • Moderator
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #6 on: December 27, 2010, 09:10:32 AM »
(Pi x r^2) x L x N
Pi =3.14159....
r==1/2 drill dia
N= number of holes
Sorcery! Burn him at the stake!
No.
Offline crazypj
  • I'm brill, me
« Reply #7 on: December 27, 2010, 02:07:04 PM »
To increase the area for cooling as a rule of thumb, the holes have to be smaller than the disc thickness
Offline fastbroshi
  • Puppet
« Reply #8 on: December 27, 2010, 06:15:39 PM »
(Pi x r^2) x L x N
Pi =3.14159....
r==1/2 drill dia
N= number of holes
Shouldn't it be (2 pi r)* h * number of holes?
http://www.math.com/tables/geometry/surfareas.htm#cylinder
Online scottly
« Reply #9 on: December 27, 2010, 06:17:39 PM »
(Pi x r^2) x L x N
Pi =3.14159....
r==1/2 drill dia
N= number of holes
Oops! This formula gives the volume of the holes, not the surface area! Still useful, regarding drilling discs, with regards to weight removed. Multiply the result by .290, which is the weight in pounds of one cubic inch of stainless steel.
The surface area inside the hole is pi x dia x L
The surface area of the flat area of the disk, were it not drilled, is (pi x r^2) x 2
Break out your calculators, class, and see if the holes have to be smaller than the disc thickness to increase the surface area.  (I measured a couple of stock 750 discs: .270")
Offline fastbroshi
  • Puppet
« Reply #10 on: December 27, 2010, 09:27:33 PM »
So trying to find the volume assuming a 4mm hole and a 5mm disk thickness, I get 62.83mm cubed.  Multiplied by 0.29, I got 18.22.  is that ounces?  Am I doing that right?
Online scottly
« Reply #11 on: December 27, 2010, 09:41:16 PM »
Convert 62.83 mm cubed to cubic inches, then multiply by .29 to get the weight.
To make things easier, do your calculations in inches in the first place; then you won't have to do the conversion from metric.
Offline fastbroshi
  • Puppet
« Reply #12 on: December 27, 2010, 09:51:39 PM »
DAMMIT!!  Thanks Scott, right in front of me!  So with 100 4mm holes, your weight savings would be .717 lbs or 11.4oz, not too shabby.  Not to mention some extra cooling.
Online scottly
« Reply #13 on: December 27, 2010, 09:58:38 PM »
I'll have to check the math, but I'm guessing that is an optimistic weight loss for 100 4mm holes..
Online scottly
« Reply #14 on: December 27, 2010, 10:07:01 PM »
I came up with .15243 pounds for 100, 4mm dia holes, in a .270 thick disc.
Offline fastbroshi
  • Puppet
« Reply #15 on: December 27, 2010, 10:21:29 PM »
Can you show your math because I just did it again and came up with something different.
Offline crazypj
  • I'm brill, me
« Reply #16 on: December 27, 2010, 10:23:21 PM »
I drilled my Yamaha XS650 discs and 'lost' a bit over two pounds  (weighed them before and after drilling)
They are probably the heaviest discs ever fitted to a motorcycle though ;D
 Use half inch holes, but, I could afford to loose some surface area as I fitted dual disc and 4 piston calipers.
 Twin disc models have smaller diameter discs, I used two 'single disc' which are larger dia.
Online scottly
« Reply #17 on: December 27, 2010, 10:39:16 PM »
ex: 100- .250" holes, in .270 thick disk:
.125 x .125 = .01565, x3.14 = .0490625, x .270 = .0132468, x 100 = 1.32468 x .290 = .38415 pounds.
pj, depending on the thickness of the discs, the break-even point between internal surface area for cooling, and the swept area is about .5" holes.
Offline fastbroshi
  • Puppet
« Reply #18 on: December 27, 2010, 11:01:10 PM »
Ok I've got it Scott, ty.
Online scottly
« Reply #19 on: December 27, 2010, 11:18:41 PM »
Hey, sorry for the hi-jack, but are you interested in the up-coming rally? 10 miles, 100,?
Offline fastbroshi
  • Puppet
« Reply #20 on: December 27, 2010, 11:32:26 PM »
I'll have to read over the thread again for details on when it goes through Texas, but most likely.  Hell, Texas alone is quite a ride, at least 12 hours if you don't stop for nada.
Offline lone*X
« Reply #21 on: January 01, 2011, 06:15:16 PM »
Orange to El Paso is 856 miles.  At the speed limits on I10 that is 13 hrs 26 minutes.  Course someone could cheat and cut across a corner.  ;D
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Online scottly
« Reply #22 on: January 01, 2011, 06:44:32 PM »
lone*X, welcome aboard! Check in here:
http://forums.sohc4.net/index.php?topic=81307.0
gsnorcal
« Reply #23 on: January 01, 2011, 07:22:59 PM »
I'm sure this will be the most useless post I ever made on the interwebs... (and I hope I'm correct in my formulas)
Surface area of an undrilled disc is:
pi*R^2 - pi*r^2 + 2*pi*R*h + 2*pi*r*h
Where:
R is the outer radius
r is the inner radius
h is the thickness
If you drill it, you loose area on the flat surface if the disc:
- n*pi*q^2
but gain the cylindrical walls of the drilled holes:
+ n*2*pi*q*h
where:
n=# holes
q=radius of holes
So, the complete formula for a disc's surface area is:
pi*R^2 - pi*r^2 + 2*pi*R*h + 2*pi*r*h - n*pi*q^2 + n*2*pi*q*h
or
surface of disc - center of disc + outer column + inner column - drilled surface + drilled column
Whew!
[Reference: http://math.com/tables/geometry/surfareas.htm#cylinder]
« Last Edit: January 01, 2011, 07:25:55 PM by gsnorcal »
« Reply #24 on: January 01, 2011, 11:21:12 PM »
if you are ding nominal like 1/2 or 3/8 holes, you can look up the weight(per foot) for steel bar, then x thickness of rotor x # of holes.. to figure weight..
