Author Topic: First Bike Build CB550k  (Read 15572 times)
Offline jiggliemon
Re: First Bike Build CB550k
« Reply #50 on: July 02, 2012, 01:46:41 AM »
@Walker Brothers, That's a good looking bike.
I was able to source the headlight to an old Ducatti or Aprilla thanks to someone from the thread reading the letters correctly.
What did you get those forks off of?
Offline jiggliemon
« Reply #51 on: July 14, 2012, 01:38:45 PM »
So I got my GSXR front end for $350 shipped. I still need to get the bearings and the top clamp. Also I need to grab some stainless spokes, but I'm not sure what size I need.
Other than purchasing, I got the tank sitting on the frame with the knee dents cut out and in their rough positions.
I ave a strong suspicion that I'll need to re-make the seat, as there's only about 12" of sitting area, and I still need to get the seat pan upholstered.
« Last Edit: July 16, 2012, 08:11:23 PM by jiggliemon »
Offline jiggliemon
« Reply #52 on: July 19, 2012, 12:22:57 AM »
I've mounted the forks. Unfortunately I didn't add a spacer at the bottom before I pressed the bearing and I need to re-press the bottom bearing.
Anyone familiar with the proper thickness of spacer that goes between the triple tree and the lower bearing?
Offline jiggliemon
« Reply #53 on: March 12, 2013, 08:43:06 PM »
I've gotten my engine back from the engine guy, 1/2 done.  So I'm starting to assemble the head, when I realize that the cam I received was for the late model Cb650. I need to get the cam from the 79'-82' model.
Anybody have a cam that they aren't using?  I'm in the market for one.
Offline jiggliemon
« Reply #54 on: March 18, 2013, 01:38:48 PM »
I went ahead and decided not to modify a stock tank.  The metal was so thin (22ga) and it was more or less a disaster for me.  So I started to make a new tank, using the "best practices" I've seen espoused around the internet.  Here's the progress:
The Buck I made
Here's some test pieces to see if the available tools could do as needed:
Offline goldarrow
  • one day, i'll be an
« Reply #55 on: March 18, 2013, 02:00:08 PM »
I feel that the tank is going to look awesome.  I think you should do a mass production  ;)
CB550 K0
« Reply #57 on: March 18, 2013, 05:29:13 PM »
The buck and the tank look great. Wow! Make a bunch in aluminum and sell them!!
Offline jiggliemon
« Reply #58 on: March 27, 2013, 05:03:50 PM »
Since this project is an insanely slow build, Im going to just put up some photos of the tanks progress.
I have to tig weld the aluminum.  I'd rather gas weld it, but the torch at the shop doesn't accept the tips, Tig's OK, but it's just 4x hotter than an OA weld.
It's been alot of fun though.
I don't know if I like the shape, so there might be a take-3 on a gas tank.  Let's hope not.
Offline Bluegreen
« Reply #59 on: April 09, 2013, 09:29:37 PM »
Just keep doing awesome !!
