Author Topic: Brake piston  (Read 1875 times)
Offline 6adan
Brake piston
« on: March 26, 2006, 09:44:44 PM »
Got a queston about brake pistons.Can anyone see a problem with making a piston out of aluminum?Have gotten several calipers from a salvage yard but all the pistons are bad. Dannie
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
Offline Clyde
Re: Brake piston
« Reply #1 on: March 27, 2006, 12:33:13 AM »
Brembo changed from chrome plated steel to aluminium pistons about 1982, but they coat them with some process to prevent corrosion. I have a Brembo kit here and it looks good with the dual piston calipers.
Brembo also have a rubber skirt seal to prevent moisture and dust getting in between the caliper body and the piston
I would prefer stainless steel rather than Aluminium, mainly from a corrosion point of view. There are usually a few on eBay
Regds Clyde
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
Offline byidesign
Re: Brake piston
« Reply #2 on: March 27, 2006, 06:43:39 AM »
If you have a local plating house that does anodizing, they will hold up OK.{made some}
    if you have them "hardcoated" it will add a little to the diameter.
     so be aware of that, when you make them.
         hope it helps
                 Bruce
82CB650SC,80CM400
Offline dusterdude
Re: Brake piston
« Reply #3 on: March 27, 2006, 07:01:38 AM »
stainless steel
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Re: Brake piston
« Reply #4 on: March 27, 2006, 07:40:01 AM »
Alloy in Alloy NOT a good idea due to corrosion
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
Re: Brake piston
« Reply #5 on: March 27, 2006, 09:36:05 AM »
I bought a phenolic one.  It's machined a bit long so as to eliminate the need for the nylon washer between the piston & brake pad.  I'll try to dig up the guy who's selling them.
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
Offline byidesign
Re: Brake piston
« Reply #6 on: March 27, 2006, 11:45:28 AM »
I made replacements for my cb650 Alum + hardcote, changed pads for the
 2nd time in {5yrs.} dissassembled and cleaned calipers, they look like they were
    installed yesterday.We have hardcote done on gage tooling assemblies,
      and it will even withstand salts, and mild acids,tech has come a loooong way..
         Hope it helps
                   Bruce
82CB650SC,80CM400
