Author Topic: 350f front hub  (Read 1302 times)
Offline nk140
350f front hub
« on: February 10, 2011, 04:58:04 AM »
Is the front bearing retainer a right hand thread?  If so I am pretty sure the shop I stopped at screwed up my hub.  Thanks
P.S.  I just searched for this
« Last Edit: February 10, 2011, 05:05:23 AM by nk140 »
  • Be careful you might get a
Re: 350f front hub
« Reply #1 on: February 10, 2011, 05:38:36 AM »
I think it's a right hand thread. What's the problem?
Offline nk140
Re: 350f front hub
« Reply #2 on: February 10, 2011, 05:46:04 AM »
the tried to remove it for me since I don't have the correct tool.  From the looks of it they went the usual direction to get things off and may have stripped the threads and locked the retainer in place.  Also the retainer is beat to hell so I think they used the same tools that I could have in my garage.  I may be looking for a new front hub soon unless someone can inform me that the retainer is a regular thread.
Re: 350f front hub
« Reply #3 on: February 10, 2011, 05:46:49 AM »
Post a pic.
Offline nk140
Re: 350f front hub
« Reply #4 on: February 10, 2011, 05:50:00 AM »
I will here in a few, but I have to use a coworkers camera phone.
« Last Edit: February 10, 2011, 06:06:43 AM by nk140 »
Offline nk140
Re: 350f front hub
« Reply #5 on: February 10, 2011, 06:07:09 AM »
Pic added....After looking at the thread I can see I think they went the correct direction.  If I remember correctly they said it turned about 2 full rotations and then stopped.
Offline ttr400
    • ttr400 Projects and Billet parts.
Re: 350f front hub
« Reply #6 on: February 10, 2011, 06:09:46 AM »
Yes it is a normal right hand thread. hub looks ok......carry on, they do get destroyed quite often when they have not been out for a while and if the stakes have not been drilled. the retainer is still available new.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Offline nk140
Re: 350f front hub
« Reply #7 on: February 10, 2011, 06:22:45 AM »
Sweet.  That is what I wanted to hear.  I will just pound away on it and just order a new retainer.
Re: 350f front hub
« Reply #8 on: February 10, 2011, 09:46:25 PM »
I had to break one into pieces one time because it was so stuck. Remember to strike the new one when you install it.
Offline nk140
Re: 350f front hub
« Reply #9 on: February 11, 2011, 05:50:28 AM »
I got the retainer out yesterday but it is fubar.  I will be ordering a new one soon.  What do you mean by striking it?
Offline mrrch
Re: 350f front hub
« Reply #10 on: February 11, 2011, 05:57:06 AM »
Take a centerpunch and put a couple of "strikes" to lock the new lock ring in place. Not too hard though. You can see them in your pic.
« Last Edit: February 12, 2011, 05:10:43 AM by mrrch »
my build
Re: 350f front hub
« Reply #11 on: February 11, 2011, 09:18:37 PM »
Take a centerpunch and put a couple of "strikes" to lock the new lock ring in place. Not too hard though. You can them them in your pic.
Yes, those little circles punched into the original piece you can see in the pick are the strikes.
