Author Topic: Fork leg allen bolt issue  (Read 5417 times)
Offline wixil
  • gas passing
« on: February 21, 2011, 10:24:48 AM »
I swapped my fork seals and gators last weekend on my K6, and I can't get the allen bolt in the base of the fork leg to tighten on one side. I tried compressing the fork with a ratchet strap to keep the fork tube from spinning, but no luck.  I did the swap with the forks still on the bike, so I'm not sure what my options are for getting the tube to remain still without taking the forks off.  I have searched a bit, but this forum is so huge I'm not getting great results.  Anybody with more brains than me got an idea or two?
Offline Silverback
Re: Fork leg allen bolt issue
« Reply #1 on: February 21, 2011, 10:44:34 AM »
Wooden broomstick!
Chris
"It's hard to define soul. You get it in art. You get it in music, and occasionally you get it in machinery."
78 CB750F racer
78 CB750F stock
75 CB750K Baby Blue Sold (She was a great bike!)
71 CB750K (rusty rod)
77 cb550F Sold :(  Bought it Back :)
Basket case 73 CB750, 77 CB750F (Building now)
01 Aprilia Falco
76 kz400
96 BMW K1100LT
Offline Kong
« Reply #2 on: February 21, 2011, 10:44:50 AM »
Put it on with an impact wrench, but be careful not to over-tighten it.  Same thing when they spin when you're trying to take them out, just use an impact and the bolt will do what you want it to.  Basically the principle is that the repeated impacts from the wrench - little shock waves - have the inertial mass of the damper tube plus whatever friction the spring offers to hold the damper from moving as much as the bolt is.  Whatever, it works.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline wixil
  • gas passing
« Reply #3 on: February 21, 2011, 11:00:05 AM »
Thanks for the input guys.  I'll borrow an impact after work and see if I can get it to snug it up.  If that doesn't do it, then I'll try the broom stick method.  I'll post the results.
Offline johnrdupree
« Reply #4 on: February 21, 2011, 11:08:53 AM »
I just disassembled the forks on my 550 and had the reverse problem, I couldn't get one of the allen screws to loosen.  The broomstick didn't work for me so I make a "special tool" to hold the damper rod in place.  It's just a socket with a groove cut in it to fit over the pin in the top of the damper rod.  I had one fork apart already so I found a socket that would fit inside the rod and cut the groove with an angle grinder and cutoff disc.  I have pics at home and will post them with some measurements after work.
That, and a lot of extensions, let me hold the damper rod still while spinning the allen screw.
~john
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
1954 NSU Lambretta 125 (long term project)
Offline kaceyf2
« Reply #5 on: February 21, 2011, 11:19:38 AM »
The broom worked for me on an f2 , but I cut the handle down so it rested on the naughty bottom tube, and was just long enough to get the top fork bolt in a few turns to put some pressure on the tube.
If you try this, tidy up the sawn end of the broomhandle so you dont leave splinters or other debris in there. ooh, and hide the rest of the broom from mum/wife/sister/janitor, and practice "knowing nothing about that" for when its found...
In my own experience...
It wasn't a Previous Owner who didnt know what he was doing that messed up your bike, it was The Previous owners mate who THOUGHT that HE did.
Offline mrbreeze
  • Not your average
« Reply #6 on: February 21, 2011, 12:52:57 PM »
+1 on the impact gun.Just give it short little blasts and it will come right out/tighten up either way.
MEMBER # 257
Offline johnrdupree
« Reply #7 on: February 21, 2011, 07:11:22 PM »
Here's my damper rod holder:
The socket is a 3/8" but a 10mm would have worked, too.  The groove is about 3/8" deep and about 3/16" wide.
Depending on how many extensions you have, you may have slide the lower up as far as it will go to get the damper rod within reach.
~john
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
Offline mrbreeze
  • Not your average
« Reply #8 on: February 21, 2011, 07:36:24 PM »
~john
Nothing like inginuity in the entire world!!!!..........Gud job McGiver!!!! ;D
MEMBER # 257
Offline wixil
  • gas passing
« Reply #9 on: February 23, 2011, 03:59:12 PM »
Well I ran out of light yesterday after borrowing my dad's electric impact.  Today I hit it with the impact, and it it was cinched up in no time.  John, good job on the improvisation.  I like the make-your-own-tool mentality.  Now that my seals are done, I can finally get around to swapping my rusted and busted 4-4 setup for my F header.  Thanks again for all the input fellas.
Offline Slams77
  • Naturally Aspirated
« Reply #10 on: February 23, 2011, 05:23:45 PM »
~john
Very nifty, I will be giving this a shot when I do the same procedure on my bike if the impact gun method doesn’t work.
Offline cobrajunkie
« Reply #11 on: February 23, 2011, 05:45:48 PM »
Impact worked great for me during R&R of the forks.  Make sure you anneal or replace the copper washer.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #12 on: February 23, 2011, 05:53:26 PM »
Loosen up the allen bolt and top cap with the wheel attached before you tear everything down. You don't need a broomstick or an impact wrench for that.
Offline cobrajunkie
« Reply #13 on: February 24, 2011, 04:16:00 AM »
Can't get to the allen bolt with the wheel attached.  You mean the fork attached.. right?
This YouTube video was very helpful for a newb like me as a prelude to replacing the seals.
« Last Edit: February 24, 2011, 04:23:44 AM by cobrajunkie »
« Reply #14 on: February 24, 2011, 11:41:50 AM »
Yep, I forgot you can't get at the bolt with the axle in. The triple acts as its own vise.
Offline cobrajunkie
« Reply #15 on: February 24, 2011, 12:09:01 PM »
"big screwdriver.. big, big, screwdriver"   ;D
Offline Kong
« Reply #16 on: February 24, 2011, 02:22:14 PM »
I have a 4-foot-long pry-bar that pops fork seals out effortlessly.
1978 Honda CB550K
1977 Honda CB550K
Offline mrbreeze
  • Not your average
« Reply #17 on: February 24, 2011, 02:39:57 PM »
I'll bet it does!!!! Whoa............talk about overkill!!!!!    ;D
MEMBER # 257
