Author Topic: 350F handlebar control Wiring  (Read 1489 times)
Offline socalenduro
« on: November 30, 2010, 06:06:18 PM »
I just added a set of cafe ace bars and i need a bit of help on the controls.
I have what seems to be a 350 twin right hand control. and there are 2 extra wires. (all the buttons/switches are the same)
Assume all the others are the same the extras are a White/Yellow and a 2nd black
HELP!!!!
Old
Black             Black/White
White             Brown/White
Blue              Yellow/Red
Red/White
New
Black              Black
Black/White     Brown/White
Yellow            White
White/Yellow   Yellow/Red
Blue
Online HondaMan
Re: 350F handlebar control Wiring
« Reply #1 on: November 30, 2010, 06:28:18 PM »
HELP!!!!
Old
Black             Black/White
White             Brown/White
Blue              Yellow/Red
Red/White
New
Black              Black
Yellow            White
Blue
Here's the standard SOHC4 functions, by color:
Black = Ignition power to the switch.
Black/White = Power from the Kill switch to the Ignition coils.
Yellow/Red = power to the Starter solenoid. This circuit varies, depending on whther the 35F had a safety module of not. In the "not" case, the other side of this switch came from Black. In the "yes" case, the White/Yellow might be the other side of the Start switch.
Blue = headlight HI beam.
White = Headlight LO beam.
Brown/White = tail and instrument lights. This is fed power from one of the Black wires.
In most of the 350 bikes (twins or Fours), those 2 Balck wires are not connected together in the switch, so they must be connected together in the headlight bucket. One of them feeds the lights, while the other feeds the Kill switch.
 Hope that helps?  :)
Offline socalenduro
« Reply #2 on: November 30, 2010, 07:08:09 PM »
sure does...
was hoping you might run across this one as you have answered (and correctly solved) about 3 other wiring issues for me!
Online HondaMan
« Reply #3 on: December 05, 2010, 08:52:56 PM »
Great license plate!  :D
Offline socalenduro
« Reply #4 on: December 06, 2010, 06:55:22 PM »
thanks! i just got it about 3 weeks ago... hasn't seen the road yet...
so everything seems to be working except the low beam of the headlight....
ideas?
Offline fasturd
« Reply #5 on: December 10, 2010, 03:39:25 PM »
Low beam filament might be burnt out. Use the beeping part of your voltage meter and check the filament.
13 in the garage and counting...
Link to my link...   http://forums.sohc4.net/index.php?topic=58422.0
Offline socalenduro
« Reply #6 on: December 13, 2010, 06:59:54 AM »
I sounded it out yesterday with my meter, filament seems to be fine...
any other ideas?
Online HondaMan
« Reply #7 on: February 22, 2011, 11:53:42 AM »
Maybe check for voltage at the connector on the back of the headlight? I've seen where someone has removed the little flat clips that were in them, then reinstalled them differently, before. This was a way to make both filaments come on with one switch setting before halogen headlights came around and improved things for everyone. The 35w headlight on the 350F attracted this technique with college kids I knew, followed by low battery problems as the alternator could not keep up with the then 70w headlight.  :-\
This presumes that the headlight is not Honda's Stanly unit with the leads hanging out of the glass, but has been updated to have the connector plug and the plug-in beam bulb or the replaceable bulb element (I think Rocky made those back then).
Offline faux fiddy
  • bike in a box
« Reply #8 on: February 22, 2011, 12:50:44 PM »
ideas?
Run hi-beam 24-7 and run it .  That's what a friends 200 has come to, low is too dim.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
