Author Topic: cb550 wiring issues  (Read 1972 times)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
cb550 wiring issues
« on: April 01, 2006, 11:17:31 AM »
okay, i might as well just start this thread vaguely, because i'm likely to have some more puzzles for you sherlocks. here's the situation:
i wired up my cb550F. i used the switches from my '77cb550K, because the wires don't run through the bars. they apparently came stock with a cutout where people like to dremel the others to allow the wires to come straight out the side of the housings, avoiding the bars altogether. before using these, i checked and all of the wires matched on both styles, one having bullet connectors and the other having multi-pin clips. this was no problem, i just got new connectors. i have a few random wires running around with no mate, but this isn't my first problem. (i'm tracking them down in my honda manual PDFs, but if anyone knows these colors by heart chip in...br/red coming from the left switch housing ('77K), bl/yellow coming from the main '76F harness).
current mystery: i have power to my hot post on my starter. the start button sends power through the y/r wire, and the clutch switch sends through the g/r wire, both tested positively, but the solenoid isn't kicking. bridging the posts the starter engages, so it's not a faulty starter. i pulled the solenoid and installed one i knew to have been working, and still no go. what am i missing here?
« Last Edit: April 01, 2006, 11:20:40 AM by paulages »
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline paulages
  • 1976 cb735
Re: cb550 wiring issues
« Reply #1 on: April 01, 2006, 11:26:08 AM »
okay, i might have solved my own problem...need to check that the neutral switch is wired properly.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #2 on: April 01, 2006, 11:29:42 AM »
problem #2 solved (thanks wiring diagrams!). mystery br/r apprears to connect to mystery bl/y as i suspected, though it seems strange that the rest of hondas color codes are match-by-color and that one's not.  :-\ oh well.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline KB02
« Reply #3 on: April 01, 2006, 11:41:10 AM »
Are you completely solved now? Have you checked that everything is grounded properly?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline paulages
  • 1976 cb735
« Reply #4 on: April 01, 2006, 07:57:39 PM »
solved in wiring daigram world...not in the real one. still same issue. power to both the clutch and start button wires at the solenoid, but still no start motor. and the neutral indicator is indicating.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline KCs76Cafe
  • Jackson Creek,NC..Deep in the stix of the TRIAD
« Reply #5 on: April 01, 2006, 08:07:04 PM »
Try reading thru my old wiring issue posts. Sounds like you are having the same problems I was. TwoTired got me straightened out.
http://www.sohc4.us/forums/index.php?topic=7606.15
http://www.sohc4.us/forums/index.php?topic=7730.0
Offline paulages
  • 1976 cb735
« Reply #6 on: April 01, 2006, 11:14:17 PM »
i'm gonna just keep answering my own posts:
"hey paul, i have an idea. why don't you check the main connection where the "green" circuit grounds out?"
"i checked for a good ground when i installed the coils. filed the powdercoat off of the frame and everything."
"huh. well maybe you should check it again."
"well #$%*, whadaya know? i forgot to reconnect that damn main green ground. hey! everything works! thanks, paul!"
"no problem."
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
« Reply #7 on: April 02, 2006, 06:46:56 AM »
BE CAREFULL early bikes had a "hot" solenoid that grounded on the bars whilst leter ones hat "hot" bar switches and the solenoid was grounded. hope that makes sense
theunrulychef
« Reply #8 on: April 02, 2006, 06:53:43 AM »
Could this be Sober Paul answering Buzzed Paul's questions?   ;D
Offline paulages
  • 1976 cb735
« Reply #9 on: April 02, 2006, 12:27:45 PM »
i think maybe it was more like sane paul talking to lost-his-mind-from-glazing-and-sanding-all-#$%*ing-day paul.
but hey, even the perfect make mistakes sometimes.  ;)
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Jonesy
  • Shop Rat
« Reply #10 on: April 02, 2006, 05:52:34 PM »
"no problem."
HAHAHAHAHAHAHAHA!!!!!! ROFLMAO!!!! :D ;D
Offline crazypj
  • I'm brill, me
« Reply #11 on: April 02, 2006, 07:34:25 PM »
Theres also a diode under the left side panel. I think Honda called it part of the starter logic circuit.
PJ
