Author Topic: wiring harness cover repair  (Read 4540 times)
Offline Goofaroo
  • general nuisance
« on: February 27, 2011, 11:30:01 AM »
My wiring harness is in pretty good shape overall but of course it has some breaks in the cover. Besides just wrapping it with electrical tape does anyone know of a more glamorous and permanent way to repair it?
1972 CB500 four
1972 CT90
1974 CT90
1978 BMW R100S
1983 CX500
1986 GL1200 Aspencade
1986 CH150 Elite Deluxe
1984 NH125 Aero
2005 Genuine Stella 2T
2007 KLR650
2002 KLR250
1985 XR350R plated
1994 DR350SE
2004 Concours ZG1000
1987 KDX200 C
1992 KDX200 E
2010 BMW F800GS
Always room for one more.
Offline 750K8 Kev
Re: wiring harness cover repair
« Reply #1 on: February 27, 2011, 11:50:04 AM »
You could heat shrink the whole thing.  It will cost a lot more than tape,  but it will give it a nice flat smooth finish.
Offline DarcyCB400F
« Reply #2 on: February 27, 2011, 11:52:47 AM »
Here is what I have used...
Caution: this tape creates a semi permanent sheath. It cannot be unravelled. Cutting it open is the only way to remove.
http://www.gandalf.nl/pdf/SVT.pdf
http://www.moroso.com/catalog/images/72038_inst.pdf
1977 CJ360T
1977 CB400F
1980 CB900 Custom
1981 GS550L
1989 DR200R
1998 VT1100C2 ACE
1999 XR400R
2006 CR230F
2007 HD Road King
Offline Goofaroo
  • general nuisance
« Reply #3 on: February 27, 2011, 12:07:27 PM »
That self vulcanizing tape looks like the ticket. I think I've seen it in the parts department at the BMW shop so I'll run by there at see if I can pick some up. I'll be heat shrinking everything that I can but in a lot of areas I can't fit heat shrinking over the end to access the broken area.   Thanks!
1972 CB500 four
1972 CT90
1974 CT90
1978 BMW R100S
1983 CX500
1984 NH125 Aero
2007 KLR650
2002 KLR250
1985 XR350R plated
1994 DR350SE
1987 KDX200 C
1992 KDX200 E
2010 BMW F800GS
Offline swellguy
  • An electric cattle prod is a
  • Divorce is so expensive because it's worth it.
    • http://ksphotos.com
« Reply #4 on: February 27, 2011, 12:20:07 PM »
I use Tech Flex braided wire wrap:
They have a number of different sizes and is easily wrapped and unwrapped if you need to access or the loom or run more wires.
http://www.techflex.com/
This project started in confusion and will end in disarray.
http://forums.sohc4.net/index.php?topic=76471.msg852227#msg852227
« Reply #5 on: February 28, 2011, 02:21:10 AM »
bmw will be dear,electrical supply shops should have it,we call it "iso bond "here.
Offline stueveone
« Reply #6 on: March 01, 2011, 11:04:00 PM »
