Author Topic: What type of media should I use for Blasting aluminum?  (Read 1219 times)
Offline Elniniomuchachos
« on: March 06, 2011, 02:34:16 PM »
I have a sand blaster, but I'm not sure which type of media I should use. I want to get that dull aluminum finish. Similar to what the bikes aluminum parts came out of the factory. Any ideas?
Offline MoMo
  • Ride like you're invisible
Re: What type of media should I use for Blasting aluminum?
« Reply #1 on: March 06, 2011, 02:38:19 PM »
I use glass bead, I think it is 80grit, cost about $20 at Harbor Freight and does not damage the aluminum...Larry
Offline Ernest T
« Reply #2 on: March 06, 2011, 05:03:59 PM »
Ditto the glass bead, I've also used crushed walnut, but its not very aggressive.
Offline CycleRanger
  • No comment about being an
« Reply #3 on: March 06, 2011, 05:06:33 PM »
I used glass beads from HF to good effect as well.
« Reply #4 on: March 06, 2011, 05:26:48 PM »
If you're going to paint aluminum parts aluminum oxide is another good option.
« Reply #5 on: March 06, 2011, 05:33:46 PM »
Medium soda takes the paint off well then a little white scotch brite removes the stains. It leaves it pretty smooth and satin looking. Works well on something you would polish too.
