Author Topic: I.D. this sprocket cover please.  (Read 1024 times)
Offline Magpie
« on: April 02, 2011, 05:48:25 PM »
Hi!
 I've had this in a box of spares for awhile and curious what model of 750 it came from.
Thanks for your help.
Cliff.
Offline daley
Re: I.D. this sprocket cover please.
« Reply #1 on: April 03, 2011, 08:36:50 AM »
Try going to Bike Bandit and look at the exploded diagrams. Maybe you'll get a hit.
Offline Magpie
« Reply #2 on: April 03, 2011, 09:42:27 AM »
Could you narrow that down a bit please?
Cliff.
Offline CycleRanger
  • No comment about being an
« Reply #3 on: April 03, 2011, 10:03:25 AM »
Well, I wasn't aware that there were any differences, BUT looking at the the three I have here, '73, '74, and '76, (all identical) I see that yours is a little different on the inside.
So it's not those years!
-I learn something new every day.
« Last Edit: April 03, 2011, 12:42:12 PM by CycleRanger »
« Reply #4 on: April 03, 2011, 10:35:24 AM »
Ah, the cover of Bad News!!
 I looked last nite & thought black motor 77/78
 There was several styles over the years.
 Variances I noticed were in the notch area behind the case numbers.. top bolt area. I think some used a washer or case guard, and some did not.. also a difference in that fat post in the middle of chain run area.. some had the rubbery sleeve over it and some I think did not.
 Noticed something odd on a 78K recently... the sprocket cover was nearly impossible to get out it was hitting. surprisingly the owner who had several other covers, did not file the cover, but rather the filed away on the frame.. :o
 On my 836 I have cut the lower bolt area off, only use the 1 bolt, real easy to get the cover off..
« Reply #5 on: April 03, 2011, 10:45:29 AM »
Does not look like my K7.
Offline Old Scrambler
« Reply #6 on: April 03, 2011, 11:23:49 AM »
It looks like the one I need for my very late K0 motor (jsut a few hundred before the K1 started) that has a factory installed case-protector..........if I remove the case-protector I think a standard cover will fit.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
