Author Topic: 1976 cb550k Battery confusion...  (Read 2156 times)
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« on: April 07, 2011, 07:41:34 AM »
I am looking to buy a battery local today, and from my research thought that I was supposed to end up with a YB 12A-A. When I went to pull te battery the PO had installed, I realized for the first time that it's a FB14L-A2. It has the name "Hi Dash" on it.
Can someone please confirm for me that the YB 12A-A would be the correct type.
Also, does this one that's been in there hurt anything?
I've been charging/tendering this thing for a months now, and ashamed I never checked it out.
Thanks
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
Re: 1976 cb550k Battery confusion...
« Reply #1 on: April 07, 2011, 07:45:54 AM »
The one you have is a 750 one and is just a bit bigger both physicaly and electricaly.
The 550 should have a 12N12A-4A-1 which converts to a 12A-A
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #2 on: April 07, 2011, 07:56:15 AM »
Thanks!
~Sophocles
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #3 on: April 12, 2011, 10:43:47 AM »
hey at least your PO didn't cut the battery cage to fit a bigger battery!
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #4 on: April 12, 2011, 11:15:27 AM »
The YB 12 is the Yuasa thicker bigger plate version of the 12N12A-4A-1 with the same outer dimensions.  I prefer the YB-12.
BEWARE the 750 battery has larger external dimensions.  I'm not sure how one was jammed into the space available on the CB550.
Also, the 750 Batteries have the terminal polarity reversed, compared to the 550.  So, WATCH OUT! and observe closely what battery cable goes where.  Not just what will reach to the convenient terminal.
bollingball
« Reply #5 on: April 12, 2011, 11:40:23 AM »
As usual good advice from TT :)
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #6 on: April 12, 2011, 11:47:16 AM »
Thanks gang. I ended up with the Scorpion battery listed in the thread that sparked my question (pun intended, ba dump dum!!!).
It was a hair smaller than my old one, and seems quite a bit lighter (good for when I need to haul the thing in from the curb to the tender!).
Measured it, wondering if I was supposed to have to charge it first. It measured over 13, higher than my old one ever did.
Got it installed without issue, but thanks for the heads up. If nothing else, I have a (un)healthy amount of fear for electrical, so I triple checked before putting it on the bike.
So excited to finally have a solid battery, taking that one component out of the equation.
~Sophocles
bollingball
« Reply #7 on: April 12, 2011, 11:58:09 AM »
Hey Nort what type did you get wet? AGM? Gel? Double A ;D Where and how much?
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #8 on: April 12, 2011, 12:17:34 PM »
I ended up with AGM from BatteryStuff.com. $59 with standard shipping, and it arrived 2 days later!  Totally happy with that.
Of course, I only got to put it in, fire it up and turn it right off. Then I got hammered with a cold. Ugh!
~Sophocles
