Poll
Are cycle x connecting rods any good?
Yes
12 (92.3%)
No
1 (7.7%)
Total Members Voted: 12
Author Topic: cycle x connecting rods  (Read 7858 times)
Offline orkid1989
  • “Life is too important to be taken seriously.”
« on: April 25, 2011, 02:55:38 PM »
i was wondering if anyone has any experience with cycle x rods? i am considering buying some for my 71 cb750 build. it is a 849cc pistons and cam plus tensioners and chains.
“Experience is the name every one gives to their mistakes.” Oscar Wilde
Offline orkid1989
Re: cycle x connecting rods
« Reply #1 on: April 26, 2011, 05:08:12 PM »
from what ive heard they are a bit heavier but are much stronger than stock rods
« Reply #2 on: April 26, 2011, 05:26:28 PM »
My assumption is they gain their strength from their added bulk. I do not know if the metal being used is any different than stock rods. That would be a good question posed to CycleX.
Offline orkid1989
« Reply #3 on: April 26, 2011, 05:33:43 PM »
here is a link to the page http://www.cyclexchange.net/Superrods%20Page.htm
they sure do look cool
Here is the difference in the bolts
in these pics they do look a bit thicker
not sure how accurate all these are but here are they specs they give
DETAILS:
Stock Honda CB  rods..............375 grams ( Fluctuate in weight )
Super rods.............................. 372 grams
Forged from S45C and heat treated to HRC 23-28.
Small end bushings are Phosphor bronze.
Big end bolts are SCM435.
Torque spec is 30 foot pounds.
« Last Edit: April 26, 2011, 05:35:21 PM by orkid1989 »
Offline kos
    • m3racing.com
« Reply #4 on: April 27, 2011, 02:44:24 PM »
Just the fact they have bronze bushings make them worth the cost.
I sell all Cycle X products.
KOS
Mark@m3racing.com
220...221, whatever it takes.
Offline orkid1989
« Reply #5 on: April 27, 2011, 06:37:07 PM »
KOS
Mark@m3racing.com
why is that?
« Reply #6 on: April 28, 2011, 04:31:21 AM »
KOS
Mark@m3racing.com
why is that?
Bronze retains oil better, dissipates heat better and is a dissimilar metal which improves wear characteristics. It won't gall pins.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #7 on: April 28, 2011, 05:55:30 AM »
Ken makes great products.Using his 4-2-1 pipe now.Has lots of excellent stuff now with more on the way. ;) ;D Thanks Ken,we appreciate you.Bill
BentON Racing Website
BentON Racing Facebook
Offline gnarlycharlie4u
  • Far from being an
« Reply #8 on: April 28, 2011, 08:37:58 AM »
KOS
Mark@m3racing.com
why is that?
helps prevent this sort of thing from happening:
« Reply #9 on: April 28, 2011, 12:27:00 PM »
Is that some top secret radiused cam journal! ;)
  • Far from being an
« Reply #10 on: April 28, 2011, 12:48:01 PM »
it's good for rpms over 18,000.
the extra surface area allows for more oil coverage, the thinner cam dissipates heat better, and the grooves keep the cam from shifting around.
shhhh don't go telling everyone about this
« Reply #11 on: April 28, 2011, 12:51:24 PM »
Quick....DESTROY ALL PICS AND FILES!!!!! ;D
  • Moderator
« Reply #12 on: April 28, 2011, 12:59:31 PM »
 ;D ;D ;D ;D ;D ;D ;D ;D ;D
« Reply #13 on: April 28, 2011, 04:37:28 PM »
Orkid, my advice to you would be to not rush out and do anything until you have been here a while and learned a bit more about these bikes. I am not trying to sound condescending at all but it seems that you are a relative new comer to this type of thing. There a piles of extremely talented builders on this forum that will answer all your questions and help you make informed decisions.  It would also help to know what you expect from your bike and how you plan on riding it, all this will help you make informed and correct decisions relating to your build..... ;)
Offline orkid1989
« Reply #14 on: April 28, 2011, 04:52:28 PM »
well this thread was mostly just about the cyclex rods. as far as my bike im not going to race it or anything. most likely will never see over 9k rpm. for the most part it will be a cruising bike.
Offline bear
  • Leeton in Australia
« Reply #15 on: April 28, 2011, 04:53:20 PM »
"There a piles of extremely talented builders on this forum that will answer all your questions and help you make informed decisions."
And at the other end of the scales there's me. ;D ;D ;D ;D ;D ;D
Brian
« Reply #16 on: April 28, 2011, 04:59:07 PM »
Brian
Hand grenades are allowed to mate.... ;)
« Reply #17 on: April 28, 2011, 05:04:04 PM »
Yeah, i know this thread is about the rods but i have also read your other threads and comments and thought i would offer some advice... ;) I would {if i were you} use your stock rods with the F rod bolts because it looks like yours isn't really a performance build, you may as well save what you can and improve other important parts like brakes and tyres and focus on reliability..... ;)
Offline wick
  • cb750k2 836
« Reply #18 on: April 28, 2011, 05:09:54 PM »
I have `em in my K2 cb750 ` 836- motor-  because- i love to romp` on it hard`` >:( >:(- no probs so far``plus-` cycle-x- under-CUT` my tranny` also`
Offline orkid1989
« Reply #19 on: April 28, 2011, 05:18:09 PM »
o ok. that was my main goal as far as the rod questioning. didnt want to put it together and a rod fail. ive already contacted mike about buying the rod bolts. i really want the bike to be reliable. i was looking at avon tyres and not really sure what you mean as far as breaking? right now i have new pads and a master cylinder rebuild kit for it if that is what you ment. what else would i do to make it reliable?
« Reply #20 on: April 28, 2011, 05:26:39 PM »
Yeah, i just meant that the money saved on parts you don't really need would be better spent on your brakes, tyres and shocks and what ever else you need to make it a reliable runner....Avons are good, Ikon shocks are excellent, brakes, well i always run dual discs and having them drilled {ventilated} is worth the small amount it costs to have them done, better cooling, better wet performance and more stopping power.....There's a guy here that does the drilling of discs for, i think, 40 USD, money well spent.... ;)
Offline orkid1989
« Reply #21 on: April 28, 2011, 06:08:56 PM »
o ok well ive got the new cyclex shocks. they look pretty cool too. i didnt think about the drilled rotors. is it hard to switch over? i know that the parts from a f2 should fit it. as far as making it reliable i was also considering an electronic ignition. either a dyna s or the cyclex one.
Offline orkid1989
« Reply #22 on: April 28, 2011, 07:14:15 PM »
quick question as far as a dual disk upgrade. i was wondering which parts will fit. the guide says 1x caliper arm 1x caliper 1x disc and i was wondering what bike those can come off of?
« Reply #23 on: April 29, 2011, 11:07:02 AM »
If you have K1 forks, you will need a caliper, arm, and "C" shaped mounting bracket from a K3 or earlier bike. I believe the same disc was used on all K models.
Offline orkid1989
« Reply #24 on: April 29, 2011, 01:03:09 PM »
o so basically i use the same parts that i already have but put them on the opposite side?
