once the gang plugs are clean remove the tank,there should be a green earth wire that goes to the coils mounting bolt on the gear shift side,clean that also, disconnect and clean the main earth from the battery to the frame,,see how it goes,,then you might need to remove the head light and carefully clean all the connections in there,,it looks a little daunting but you can do it,also with the black wires make sure if some have a white stripe they go to a white striped mate,you might need to turn the wire around to see it.,your keen to ride it but its better to sort it out before you take it out.
