Author Topic: What's the best spark plug wire?  (Read 1722 times)
Offline Artf0rm
« on: May 28, 2011, 10:51:37 AM »
Ok, I'm sure that this is opening a can of worms but I need some opinions.  I upgraded to a dynatek S and some 3 ohm dynatek coils (DC1-1) and now I m in need of a set of wires for my 750.  What should I use.  I know I keep seeing wire sets that say not for use with electronic ignition?  What's that all about?
Offline Deltarider
Re: What's the best spark plug wire?
« Reply #1 on: May 28, 2011, 01:42:25 PM »
Just plain wire, nothing special. Stay away from carbon.
CB500K2-ED Excel black
bollingball
« Reply #2 on: May 28, 2011, 05:32:14 PM »
Here is a few
http://www.z1enterprises.com/catalog.aspx?pid=CB750K-1978-EL0
You want 7mm copper core.
                       Ken
« Reply #3 on: May 28, 2011, 05:36:54 PM »
You should have resistance in the ignition spark circuit.
Pick either:
Resistance wire
Plug cap resistance
or Resistor spark plugs
Offline Artf0rm
« Reply #4 on: May 28, 2011, 07:54:56 PM »
Why stay away form carbon?  I keep seeing carbon core?
« Reply #5 on: May 28, 2011, 09:00:34 PM »
Carbon core deteriorates and degrades with age/use, and must be replaced periodically.
Metal core pretty much stays metal for far longer.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #6 on: May 29, 2011, 09:17:48 AM »
Use copper core wire with resistor caps with your setup. I would highly recommend going with the 5 ohm coils over the 3, you will see no advantage in this ohm drop, only problems.
Offline GreenHornet74
    • 4 Months on CB750s
« Reply #7 on: May 30, 2011, 02:05:12 AM »
Or you can get a resistor pack from Hondaman.
4 Month Motorcycle Trip Photo Blog...work in progress
http://sorozcojr.tumblr.com/
Offline Artf0rm
« Reply #8 on: May 30, 2011, 10:46:42 AM »
Ok, I went ahead and ordered a 7mm copper core kit by dynatek from z1.  I am just getting this thing together from the ground up so when you say "problems" with the 3ohm coils (which are brand new and I can't return) what should I be looking for?
Offline worlddrum13
« Reply #9 on: May 30, 2011, 10:57:06 AM »
i did the same upgrade last month. what an improvement! dont forget your new caps too. z1 has the best prices on the wires and caps
75 750 k6
Offline Artf0rm
« Reply #10 on: May 31, 2011, 12:21:42 PM »
That's great to hear.  I ordered this http://www.z1enterprises.com/detail.aspx?ID=1983 and the crimp tool.
« Reply #11 on: May 31, 2011, 12:58:31 PM »
Burnt out kill switch, burnt out ignition switch, these parts were not designed with 3 ohm coils in mind.
Offline Artf0rm
« Reply #12 on: May 31, 2011, 01:27:05 PM »
Cool, then I am good to go.  I'm running the cycle x ignition switch with start function and custom wiring.  I guess there are some advantages to doing it all yourself. :-P
