Author Topic: Bleed the brakes with a...  (Read 6530 times)
Offline jacquesleclochard
  • If Tin Can do it, you can do it!
    • Tin Can Customs
« on: June 05, 2011, 10:42:31 AM »
Great solution. I didn't try it myself yet, but I found the picture and just had to spread the gospel.
Offline EMS541A
  • Lights n' Sirens
Re: Bleed the brakes with a...
« Reply #1 on: June 14, 2011, 02:21:16 PM »
These syringes work great for a lot of things, including measuring out fork oil from bottles without marks on the side. If you want a free one, ask your local ER or ambulance/rescue squad if they have any expired D50 (50% dextrose) because you want the syringe. This #$%* expires faster then milk (tastes worse then expired milk, too) and they're pre-packaged with those gigantic syringes and a vial of D50. And a lot of places keep the expired meds for classes and stuff like that. Just clean the plunger after you use it or you're gonna have a #$%* of a time pushing it out, they have crappy little threads in the rubber.
While you're using it, try not to imagine that syringe pushing 50% sugar directly into your blood stream through a gigantic catheter...
« Last Edit: June 14, 2011, 02:25:54 PM by EMS541A »
Offline CycleRanger
  • No comment about being an
« Reply #2 on: June 14, 2011, 02:28:35 PM »
The brake fluid will make the rubber in the syringe swell up after a while and render the syringe useless.
You'll find that out after you use it to bleed your brakes and then throw it in your toolbox and pull it out six months later to use it again.
Tractor Supply is a great place to get various size syringes btw, since they have many supplies for medicating large farm animals. ;)
Offline zackblack
  • Give my creation... Life!
« Reply #3 on: June 14, 2011, 06:10:14 PM »
Buy them cheaply from your local CO-OP store and then throw them away after use.
:) If I ask a question and forget to post model and year my bike is a '72 CB500 :)
kaniktshaq moritlkatsio atsuniartoq: Umingmaktormiut dialect.
"Observe the snow. It fornicates."
Offline Mars
« Reply #4 on: June 17, 2011, 10:15:21 AM »
What advantage does a syringe give over using the master cylinder?
Offline HondanutRider
« Reply #5 on: June 17, 2011, 12:26:15 PM »
I believe the method in using a syringe is to push fresh fluid up the system from the caliper end, through what is usually called the "bleed screw".  The master cylinder isn't used to pump the fluid out in this method.  The advantage is that the possibility of introducing air bubbles in the line are reduced, and any air that is in the system should be more easily pushed up and out the reservoir, rather than trying to pump it down and out the bleed.
« Reply #6 on: June 17, 2011, 12:49:35 PM »
Yup, used a syringe to bleed my jeeps brakes, works resonably well, better than asking my wife to help me   ;D
Offline knochgoon24
« Reply #7 on: June 24, 2011, 01:12:21 AM »
I had one that lasted for years of brake bleeds using DOT-3/DOT-4 fluid. It wasn't until I tried to use to for gas that I killed the rubber plunger.
I'd use a piece of fuel hose to connect the syringe to the brake bleeder, then I'd hang the syringe with the "needle" end pointing down. Then all I'd have to do is pump the brakes (car or bike). It's essentially a 1-man bleeder. The clear syringe made it very easy to see when I had new fluid flowing out.
The one I had was a 60cc syringe, too. Very very similar to the one posted.
'75 CB550 F0 -- On the road again. Part 1  Part 2
'75 CB550 K1  -- temporary motor donor. SOLD.
Offline zackblack
« Reply #8 on: June 25, 2011, 10:34:03 PM »
I hook up the syringe as per the OP picture, pump the brakes a couple of times to get the fluid flowing then I pull on the syringe until there is no more air.
Easy-peasy  ;D
