Author Topic: 1973 CB500 compression at 50lbs...  (Read 2019 times)
Offline Randy
  • Nothing like a banging four under my legs..
    • Mission Detail
« on: June 18, 2011, 06:04:19 PM »
Can that be true..I took test and the gauge read 50lbs... Can the motor even run with that pressure?...It seems to run fine..
1973 CB500k, 1972 CB750 (New Arrival), 1978 Vespa P200 (New Arrival)
bollingball
Re: 1973 CB500 compression at 50lbs...
« Reply #1 on: June 18, 2011, 06:27:54 PM »
Was the motor at operating temp and the throttle wide open choke open where the reading all the same on all four??
                       Ken
Offline domer
« Reply #2 on: June 18, 2011, 06:29:36 PM »
what kind of tester are you using? method?
Offline xsmooth69x
« Reply #3 on: June 19, 2011, 02:30:33 AM »
i thought it was PSI?
well pound per square inch.....
what kind of gauge says lb?
1975 CB550 (FINISHED?!?!?)
Offline Randy
    • Mission Detail
« Reply #4 on: June 19, 2011, 08:37:26 AM »
I meant PSI.. and its a TEC from O' Reilly's.. the kind that has the metal tube and then the flex hose and then the gauge... I haven't tried oil in the cylinders yet to see if I can bring the compression up..That will have to wait..
bollingball
« Reply #5 on: June 19, 2011, 09:01:58 AM »
littlegreen: Well in short it could be true. Just remember it is more important that they are close to the same reading than what the reading is.it has been gone over a lot here TT had a good write up on it. You did say it ran fine so I would not over analyze it.
                      Ken
