umm?very little play,where the guide protudes into the ports,if the wear is bad(along with the seal)you might see tell tale baked on oil build up around the bottom of the guide in the port,or the back of the valve head looking pretty oily,ive gotten away with murder on some of the old engines ive just sort of taken apart and re assembled as a runner,,then again ive had a few smokers as well,if youve purchased the guides already and your going a rebore,new guides will go nicely,ive had these rebored and never done guides because they have been ok,i know your trying to save a bit of money(not just pocket change),see how they look,approach another engine shop like i said and with your head show them the guide wear(pick their brains),there is a specified wear limit involving dial indicators and such but i dont think you want to go buying specialist tools for a one off job?,,one last tip,,the very tip of the valve stem where the rocker screw activates it(makes contact)can develop a small "invisible" burr,this will prevent the valve coming out easily,dont force or hammer it,,just file it off gently and wipe the stem before you pull it through the guide.
